Old 04-25-2015, 08:37 AM   #1
TV Mounting Help 2016 29HFS
Guys, I want to attach the Tv Mounts in my trailer but i dont know what is behind the wall and where? In the garage there is a little sticker that says "TV Backer" What does that mean? Where on the bedroom wall is it? What is in the center room wall?
Thanks for the help.
Red900 is offline   Reply With Quote
Old 04-25-2015, 08:50 AM   #2
Bob will get you a clear answer on this. I'm guessing it's a thick plywood board behind the finish paneling so you can grab wood wherever you go in but not sure?
taken is offline   Reply With Quote
Old 04-25-2015, 02:07 PM   #3
STLfan's Avatar
It's an area behind the wall covering that is a piece of plywood which you can screw into. This is the area that you want to screw in the mount for your TV.
STLfan is offline   Reply With Quote
Old 04-26-2015, 06:21 AM   #4
Where is the TV Backer sticker in the garage suppused to be? I didn't get one of those.
DennisTD is offline   Reply With Quote
Old 04-26-2015, 09:58 AM   #5
WolfWhistle's Avatar
If you tap with your knuckle you can detect the backer. The bedroom wall has a 2x6 vertically, floor to ceiling, centered on the wall. Same in
LR. I have a 2015
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
mount, tv mount
