Old 09-27-2014, 04:19 PM   #1
TV wall outlet.
Didn't get the info on the TV wall outlet. I have found out that to use the camper antenna the cable must be on TV and wall outlet green light on. But what about cable from campground how dies it need to be hooked up? What does
the green light on the TV wall plate mean?
laurajean is offline   Reply With Quote
Old 09-27-2014, 04:55 PM   #2
The green light is for OTA antenna. It shows when your signal booster is on. When on cable hook up, turn it off...
2008 Forest River Micro-Lite 18FBR
2000 Ford Explorer Sports Trac
WBrian is offline   Reply With Quote
Old 09-27-2014, 05:57 PM   #3
Evereddie's Avatar
There is more going on inside that TV wall plate than people know. It actually has switching circuits inside and it switches between the antenna signal (green light on) and the park cable (green light off) . The antenna booster also comes on when it is on the antenna setting (green light on) but that is secondary in importance to the switching of sources. Your park cable hooks up on the outside probably under a lift up cover and it is labeled CABLE. In that cover should also be a connection for a satellite dish probably marked AUX or SAT.
Evereddie is offline   Reply With Quote
Old 09-27-2014, 06:36 PM   #4
Where would the TV plate be??? We just picked up our 340X12 last Friday and are still trying to find everything...didn't get a good walk through when we picked it up.
Wingnut647 is offline   Reply With Quote
Old 09-28-2014, 09:32 PM   #5
Just Love to Camp
TheFordes's Avatar
Mine is where my tv hooks up in the master bedroom. It is just a little black button that when you push it a green light cuts on
Camped 54 Night 2012
XLR Thunderbolt 386*12
"Bertha The LeadSled" is her name
2012 F450
Virginia
TheFordes is offline   Reply With Quote
Old 09-29-2014, 11:04 AM   #6
With my dish tailgater sat i can not get it to work going through the camper wiring does anyone else have this issue? Dish had me hook it up through the window direct to the reciver and it works great. but i didnt buy this nice of camper to have wires running through windows.
2014 29hfs XLR
2008 Ford F250 6.4 PSD
deleted and Tuned
2012 Polaris ranger 800 XP Walker Evans
turbosi44 is offline   Reply With Quote
Old 09-29-2014, 11:17 AM   #7
Evereddie's Avatar
Originally Posted by turbosi44 View Post
With my dish tailgater sat i can not get it to work going through the camper wiring does anyone else have this issue? Dish had me hook it up through the window direct to the receiver and it works great. but i didn't buy this nice of camper to have wires running through windows.
Don't know your specific camper but, are you hooking up the sat dish to a connector on the outside that says AUX or SAT? It should then come into your trailer on a wall plate with the same marking on it, AUX or SAT. That would then obviously go to your receiver. If you have done that and it is not working, try the other connection on the outside marked Cable. There have been several cases, including mine, where the outside connections were reversed in manufacturing.
electrical
