Old 05-27-2013, 10:14 PM   #1
two switches in bathroom above tank and battery readout....
The one to the right turns on the lights on the ceiling..... the switch on the left does.....? It does not operate the fan above as that has a switch near the fan that turns it on and off.
Martins5547 is offline   Reply With Quote
Old 05-27-2013, 11:09 PM   #2
I had same problem as you, although different trailer. I removed wall plate cover over the switches and found a few strands of wire from light switch touching the fan switch causing it to constantly supply power to the ceiling fan switch. Removed the wire strands and now the second switch controls the fan along with the switch by the fan.
Ken & Janet
'07.5 GMC 2500 D/A CC/SB
'09 SABRE 31RETS-6
wingriders is offline   Reply With Quote
Old 05-28-2013, 09:30 AM   #3
rah.rrt's Avatar
If your trailer has tank heaters it controls that. I have heard that if you dont have the tank heaters it controls the fan.
rah.rrt is offline   Reply With Quote
Old 05-28-2013, 09:47 AM   #4
Yes, we have the extreme package. That's great to know. It would be nice to have the fan on the switch and the heaters on the panel with the tank readouts.
