Old 07-09-2012, 08:34 PM   #1
10x
Underbelly cover for xlr 27
I noticed the underside is not covered. Is this a problem in wet weather on the plywood floors?
10x is offline   Reply With Quote
Old 07-09-2012, 10:26 PM   #2
Somewhere there is a post I made about covering the underbelly, if it bothers you. It is a "sticky" and may be under mods. I suggested using tin roof material, and screwing it to the frame. That is what is on the higher end trailers, such as a Cardinal. I undercoated mine with the spray type rubber undercoating found at auto stores. Still need to get the tin, and some insulation, and take care of that, but never enough time to do all we want to do. And yes I have a toy hauler also, just a Work and Play.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
underbelly
