Old 09-25-2015, 09:08 PM   #1
Using f150 for towing
Hi all, looking at the XLR model an wanting to tow it with my 2013 f150! Looking for opinions?? Here's the specs on my 2013.
F150 (2013) supercrew 4x4
Engine = 6.2L
Transmission = 6 speed auto
3.73 rear end
Krlpj05 is offline   Reply With Quote
Old 09-25-2015, 11:40 PM   #2
Play Harder's Avatar
Will tow it but those 3.73 gears might bog you down in the steeps --- used my dad's ecoboost w max tow 4:10 gears and couldn't believe how much torque the ecoboost has - it could from a dead stop climb any hill and get you to 60 -65 with no problems ---- the only downside was the fuel Milage when towing - also over 65 mph had to pay Attention to sway the f150 is pretty light
Get out and Play Harder😛
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015😊
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
Play Harder is offline   Reply With Quote
Old 09-26-2015, 06:11 AM   #3
oldgold's Avatar
Engine = 6.2L
3.73 rear end
Hyperlite, Nitro, Thunderbolt ? Might want to throw a model number in this equation. There is a fairly large swing between weights from a smaller Hyperlite XLR to the big 5th wheels.
I know there is a lot of back and forth on this site about F150s... I have owned probably 7 or so F150s. My last 150 was the Ecoboost. My last 2 trucks have been F250s. I'm liking the 250 way better and I even commute 50 miles into Atlanta everyday. This has all been in the last 15 years or so. Ford likes me cause I drive 60 to 70k a year.
Post up what model you are looking at...
Also, which GCWR does your truck have 13,500 or 17,100?
One issue you may have is tongue weight, especially if you are towing without a toy in the back. Our nitro has a tongue weight of about 1100 lbs completely dry, without propane, the genny, water, or anything else. It's closer to 1400 or 1500 loaded.
2015 XLR Nitro 30FQSL
2015 F250 King Ranch
oldgold is offline   Reply With Quote
Old 09-26-2015, 07:12 AM   #4
davel1971's Avatar
payload is the limiting factor most of the time with 1/2 tons. Most of the newer 1/2 tons can be equipped to be very capable pullers. Just can't handle the payload that comes with the trailers they advertise they can tow.
David & Lynn
Old 09-26-2015, 07:23 AM   #5
I've had both Ford and Chevy half tons and presently a Chevy 2500. Half tons have the power but if you are purchasing, a heavier duty truck will give you a much better towing experience. Stability, power and general handling issues are far superior imo.
2017 Salem Hemisphere 326RL
2009 Chevy Silveraldo 2500
meandmylabs is offline   Reply With Quote
Old 09-26-2015, 07:32 AM   #6
I did not think you can get a 6.2l in a Ford. It would be a 5.0 or 3.5 ecoboost.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 09-26-2015, 07:35 AM   #7
davel1971's Avatar
Raptor model has a 6.2
David & Lynn
Old 09-26-2015, 08:05 AM   #8
Yes it's a 6.2 same as the raptor.
Old 09-26-2015, 09:17 AM   #9
What does your driver side door sticker say for payload?
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 09-26-2015, 09:23 AM   #10
B and B's Avatar
This might be a SVT truck and the payload might suffer due to options. I know with my 2013 King Ranch SCREW Eco I had 400 lbs less payload due to options. I still towed 9500 lbs and 1750 pin weight. Worked OK but long term I would have toasted the rear axle.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
f150, towing
