Old 04-07-2012, 12:29 AM   #1
dsdbkranz's Avatar
Vinyl exterior decals
Hello
I have a 2008 XLR 37X12 and was wondering if anyone has been having trouble with the exterior vinyl stickers/decals pealing off. My other fifth wheel decals lasted 15 years. Is this a problem or did I just get lucky with a bad batch of vinyl decals from the manufacture. I also wonder do these things have a warrantee. Any response is appreciated.
dsdbkranz is offline   Reply With Quote
Old 04-07-2012, 09:43 AM   #2
"Flagstaff" came off the front of my 5th wheel the first time I washed it. Rest are staying on fine. Wayne
wayne anthony is offline   Reply With Quote
Old 04-07-2012, 11:15 AM   #3
YES! All of the manufacturers are using the cheapest vinyl that they can purchase. 2 to 5 years is about the life out of that garbage. Best solution, find a mobile graphics shop and pay them to replace all of them (Cheapest).
Pay a shop to peal them all off and paint on new ones (most expensive, but longest lasting). Or peal them all off and go naked.
Old 04-07-2012, 11:28 AM   #4
Whiskeyjack's Avatar
Yup they usually use cheap vinyl. Just go to some local sign/decal shops and check out replacements. They should use a premium vinyl but it won't be that cheap. Also something to keep I'm mind, most metallic vinyls although premium material, aren't rated for more than a couple years outdoors. If you are going with a printed decal make sure it's ink jet and laminated.
Whiskeyjack is offline   Reply With Quote
Old 04-07-2012, 11:12 PM   #5
dsdbkranz's Avatar
I got a quote from forest river and to replace the decals would cost me $545 I think i'm on the same page as Donn and just have them painted on and forget about every 5 years spending 500 bucks. Thanks for all the comments, unfortionatly I'm not the only one with this issue.
Old 04-08-2012, 07:34 AM   #6
Herk7769's Avatar
My side labels have "chicken pox."
Year two I started getting "pimples" about 1/2 inch in diameter.
There are about 30 on the camper now.
Only the green and red labels have the problem so I am assuming they were bad from the start.
I tried to pop them with a pin and "re-stick" them; but it is the glue underneath that is bad.
HAM CALLSIGN - KC3FFW
Old 04-08-2012, 09:57 AM   #7
Smile vinyl decals
Don't pay someone to take them off. I took some of mine off. Just take a hair dryer and heat them up. They will peel off real easy. I had some decals made up for my ramp door and put them on by myself.Also very easy. Wayne
jusme is offline   Reply With Quote
