Old 06-17-2015, 09:07 PM   #1
Wall mount tv while traveling ?
hello, I am going to install a full motion wall mount for my 24 inch flat screen and was wondering that those of you that have one already do you leave your tv on the mount while traveling, I was thinking that maybe I can secure it with a wire tie or some sort of strap, looking for input pros or cons on doing it, I would love to not disconnect the wires every time. thanks joe
joe in pa is offline   Reply With Quote
Old 06-17-2015, 09:16 PM   #2
scootingranny's Avatar
We just made our first trip in our 5er and we strapped the tv to the mount in the bedroom (it's not a big one) but it wasn't a bungee cord, it was a strap. The TV in the livingroom has an automatic lock mechanism on the back that you have to pull a chain to release so nothing needed on it...just need to make sure the tv is pushed back and it's held by that lock
2015 Coachmen Chaparral 360 IBL
2014 Ram 3500 Turbo Diesel 6.7 4wd Crew Cab Dually
scootingranny is offline   Reply With Quote
Old 06-17-2015, 09:27 PM   #3
Taranwanderer's Avatar
When you're ready to travel, push the TV up against the wall and secure it at the corners with something like these:
Robot Check
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 06-17-2015, 09:43 PM   #4
ddt111's Avatar
I mounted a 24" LED on a articulating arm to the bedroom wall. I used a nylon battery tie down strap to secure it to wall when in motion. I used a rivet gun to attach the strap retainers to the wall. One near the top and one near the bottom of tv. It works great.
2014 Rockwood 8281WS
2011 F150 4x4, 5.0, 3.73 rear
ddt111 is offline   Reply With Quote
Old 06-18-2015, 09:26 AM   #5
WolfWhistle's Avatar
See "TV mount in Nitro...." This forum for what I do.
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 06-18-2015, 09:31 AM   #6
camping baba's Avatar
When the dealer installed the full motion TV mount they used one that came with a lock built into the mount . It works great . It is used on our 21 in. TV . ��
camping baba is offline   Reply With Quote
Old 06-18-2015, 04:51 PM   #7
I have an articulated mount for my 22" tv in bedroom. When I travel, I simply slip it out of its' mounting and put it on the bed. Takes about 5 seconds. Same with mounting it back. No matter how well you strap it in on the wall, all the bouncing up and down will eventually work on the screw holding the mount on the wall. Better safe than sorry.
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
BusyRetirees is offline   Reply With Quote
Old 06-18-2015, 11:49 PM   #8
hello all, hey thanks for the replys, I ordered a full motion mount and tv tie down straps off amazon today, when I receive it and get it installed I will let you know how it works out. thanks again joe
Old 06-19-2015, 12:28 AM   #9
I installed a wall mount that is fully able to move in several directions and a 40 inch flat screen in the entertainment cabinet that came with my 5er. The TV is able to move in front of the counter seen at the left of the picture pointing toward the back window where we have our recliners. Of course it does not fit inside the cabinet. There is a strap inside of the cabinet that holds down the flat screen. I use some pillows between the back of the TV and the sides of the cabinet and tighten the strap to snug the tv into the pillows to prevent vibration damage while the camper is moving. This has worked well for three years.
Reb Kitt is offline   Reply With Quote
Old 06-19-2015, 04:56 AM   #10
Ambassador
Ken K.'s Avatar
we have a factory 24 inch in our 2502 KS. It's on a full art arm from the factory. We have been leaving it up for the road. I do collapse it down so that it's next to the wall. There's enough friction in the travel that it won't swing out on it's own during travel, or at least it hasn't yet. There are straps on the back of the TV, But we don't feel they are needed because the articulations are so tight. I guess some arms may vary and you may need those straps. but we literally have to wrestle with our TV to get it away from the wall. Might be unique in nature seems like it is reading these comments. Point is we leave it up, I guess.
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
Ken K. is offline   Reply With Quote
Old 07-05-2015, 09:51 PM   #11
hello all, hey finally got the tv mounted with the full motion mount and I mounted the hold down strap to two screws on the tv backing plate and brought the other strap back to a screw that I used for the wall mount, I feel pretty good about leaving it up now while traveling, thanks again for all the replies. take care joe
Old 06-19-2018, 11:57 PM   #12
Tmoz78's Avatar
Good info.
Tmoz78 is offline   Reply With Quote
Old 06-20-2018, 05:47 AM   #13
jd50i's Avatar
I added 2 of these, they included the straps. So far no problems since 2013.
https://www.campingworld.com/travel-tv-wall-mount
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
jd50i is offline   Reply With Quote
Old 06-20-2018, 06:55 AM   #14
Gold Tee Box
Teetime's Avatar
I like that wall mount because it is removable, but wasn't sure about how secure it would fasten to the wall.
Instead, I chose one with a bigger wall footprint that is secured to the plywood backer plate in the wall. The plywood backer is in an odd place in the upper left corner of the wall instead of being centered. To make it removable, I added the RV mounts from PAW International to the mount and TV so it's secure and removable as well.
ID:	176629   Click image for larger version
ID:	176630   Click image for larger version
Success is hiring someone to mow your lawn so you can play golf for exercise.
2018 GMC 2500 Duramax Denali
2018 Coachman Freedom Express 287BHDS
Teetime is offline   Reply With Quote
Old 06-20-2018, 08:50 AM   #15
jd50i's Avatar
In mine the mount also fastened to the wood block in the wall. I bought the removable ones because I didn't trust them holding but after forgetting to take them down I saw they road with no problems.
2014 Grey Wolf 21RR
mount, travel
