Old 03-25-2015, 09:10 PM   #1
Washing machine
Installed a used washing machine/dryer a moth ago and just unwinterized it and the drain seems to be slightly clogged or blocked. It's a 2014 XLR 395, the water dumps faster then the drain lets it go down. Any one else had this problem, Am gonna try fishing a wire down it and see if I can feel something blocking it.
the.wilsons is offline   Reply With Quote
Old 03-26-2015, 08:58 AM   #2
I would do what your doing. If your wire hits something, get a cheap snake to get the plug out. Could be a mouse nest. Something like this would work:
http://www.amazon.com/Cobra-85250-4-...ds=drain+snake
taken is offline   Reply With Quote
Old 03-26-2015, 02:52 PM   #3
WolfWhistle's Avatar
You've gotten too fancy for me, Mr. Wilson. But, I wonder how it vents? And, if the washer hose might be tight in the pipe. I had a house that did something like this and by giving the hose to pipe some clearance, it worked better. In other words, the washer hose being of smaller diameter than the drain pipe, it helped. Just a thought.
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 03-26-2015, 05:47 PM   #4
Good point! If it's vacuum locked due to a tight fit, that could be an issue.
Old 03-26-2015, 07:04 PM   #5
XLR Production
The drain line has a pop off vent located behind the access panel. Remember that the drain line bypasses your holding tanks so insure that the knife valves are open at the termination.
bulletbob is offline   Reply With Quote
Old 03-26-2015, 07:38 PM   #6
Good info Bob. This makes sense if the valve was closed. If so, the water would travel the drain line, hit the valve, then make the assent into the grey tank. Due to the convoluted route, it would drain, albeit slower than if the valve was open causing the OP's issue...
Old 03-27-2015, 08:09 AM   #7
I never really thought about how a washer would vent. So it has a Studer Valve? Then, if the hose was tight into the drain it wouldn't matter one iota. Also makes sense to bypass the tanks. I can't imagine me ever having a TH big enough to have a washer. Thanks Bob.
Hyper Lite was sold
Old 03-27-2015, 08:15 AM   #8
How about a washer/dryer combo?
Old 03-27-2015, 08:24 AM   #9
coin laundry or buy new
Hyper Lite was sold
Old 03-27-2015, 08:27 AM   #10
Coin ops are smelly places filled with strange people... and my wife already buys enough new to stimulate the economy of everywhere we go!
Old 03-27-2015, 12:28 PM   #11
Good info. Thanks
Wallace
twiggw is offline   Reply With Quote
Old 03-27-2015, 03:19 PM   #12
T, No strange places with smelly people, WW
Hyper Lite was sold
Old 03-27-2015, 09:52 PM   #13
Taranwanderer's Avatar
T--is it possible that your wife and my wife are somehow distantly related?
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 03-27-2015, 09:55 PM   #14
Good to know I'm not alone...
Old 04-01-2015, 09:30 AM   #15
Sorry for not replying sooner but we have been busy getting ready for the first trip of the season. We made it to the campground and with the grey tanks open everything works good with the washer drain. Now the refrigerator is another story. It worked good on gas at home and after a 10hr drive here it stopped working in gas and electric. Tried turning off for awhile and unhooking power to everything and still not working. Guess it will have to go in for warranty work when we get back.
Old 04-01-2015, 06:44 PM   #16
XLR Production
I have to ask the obvious question. Please don't take offense. Do you have LP in the tanks or is there 110 power?
Old 04-01-2015, 08:46 PM   #17
Occam's Razor, Bob.
breezyhillfarm is offline   Reply With Quote
Old 04-02-2015, 06:48 AM   #18
Bob yes to both. I can hear the burner light and burn and after a few minutes the outside cooling fans kick on and off. And on elec I can't hear anything but the outside cooling fans will kick on and off. But the temp never goes down. It seems to be running like it suppose to but doesn't cool off any.
Old 04-02-2015, 07:06 AM   #19
XLR Production
Another dumb question. Do you have it set at the coldest setting?
Old 04-02-2015, 07:11 PM   #20
Tried all the settings and it stayed at 78 degrees.
