Old 08-19-2012, 06:21 PM   #11
Mark and Linda's Avatar
Have you considered or looked at these:
http://www.campingworld.com/shopping/product/e-z-hose-carrier/1483
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
Mark and Linda is offline   Reply With Quote
Old 08-19-2012, 07:16 PM   #12
Taranwanderer's Avatar
Originally Posted by prof_fate View Post
As for keeping the hose inside the bumper - while I've not done it's because when I asked about it I was told - the hoses will be damp when you are done with them and bumpers are metal - you will (eventually) get rust. This rust will then act like sandpaper we you push/pull the hoses in and out. The hose included with most campers is way cheap and thin and won't last long so I bought a rhino. While the hose is the same diameter the couplings are way larger, and it included caps so the nasty stays inside - no smells.
That's a good thought about the hose(s) being wet--I usually try to drape the hose over the spare tire after I use it and before I pull out of the site so it dries out before I put it back in the bumper. Probably would be a good idea to hose out the bumper once in a while and let it drain and dry completely. The RF hose does fit into the typical square TT bumper, you just have to rotate it a little so the locking "ears" are at the corners. That said, if I didn't have a bumper that the hose fit into, I'd probably be on my way to Lowes or Home Depot for some large length and diameter PVC, mounting straps, and a screw-on end cap. Good luck!
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 08-19-2012, 07:32 PM   #13
Thank you Mark and Linda for the link to Camping World. That is what I used to go by when I made my own. I already had the pvc from another project and put a threaded flange on one end and hardware cloth (wire) on the opposite end. It has worked for the past 5 years and should last many more after I install it on the new TH.
I have often read about the inside of the bumpers rusting and causing holes to form in the stinky slinky. This is what prompted me with my last TT to make something different.
meandmylabs is offline   Reply With Quote
Old 08-19-2012, 07:47 PM   #14
My thoughts on storing in the bumper is like many others. Plus if the hose isn't cleaned good before storing you also help contribute to the rusting process. Worked around aircraft many years and a major area of corrosion was around the lavatory areas.
I have seen another mod where a plastic fence post was used with two caps, hinges and fasteners.
Old 08-19-2012, 09:12 PM   #15
great white's Avatar
My rhino flex does not fit in the bumper so it's not a solution for everyone....
2011 Flagstaff Classic Superlight 831RLBSS "Atrium slide"
Husky Centerline Hitch
2016 Ford F-150 EcoBoost SuperCrew, Lariat Sport, Max Tow package
great white is offline   Reply With Quote
Old 08-19-2012, 10:25 PM   #16
This is an easy one. The 27hfs doesn't have a bumper or a place to store it. You can add some sort of external storage or get a tote. I store mine in a tote in the generator area and keep my fresh water hose on the other side.
Toy Haulin is offline   Reply With Quote
Old 08-20-2012, 09:59 AM   #17
My personal favorite:
made with a vinyl fence post and rain gutter IIRC....
Old 08-20-2012, 10:09 AM   #18
Now that I like! What size post and gutter is it, and what did you use to attach it to the TT? Finally where is it located in reference to the wheels? I have seen those done before, but am a bit worried about dragging it.
Old 08-20-2012, 10:37 AM   #19
Use 5" square fence post cover and a pc of 4" gutter. Fence post covers attached with a bar suspended from a 1/2" threaded rod on rear of the frame. The round 4-1/2" tubes were attached with "U" straps to the bottom of the frame right in front of the wheels.
Name:	Sewer hose, connections & Driver side Sun Shades.jpg
ID:	18385   Click image for larger version
ID:	18386   Click image for larger version
Name:	PVC gutter storage.jpg
Old 08-20-2012, 11:10 AM   #20
There is no back bumper on a 27hfs to attach to. Anyone got picks on how they attached it to a 27hfs?
