Old 08-18-2012, 07:41 PM   #1
Waste hose storage
We just purchased a 27HFS (will pick up next weekend) and could not remember if this TT has storage provisions for the waste drain hose. Could anyone help us with the answer?
meandmylabs is offline   Reply With Quote
Old 08-18-2012, 08:44 PM   #2
Not specifically for the hose. The only outside storage is the front compartments. I keep the water and waste items separated in plastic tubs in there. I'm thinking of mounting a tube or long shallow box underneath behind the tires.
Rotech is offline   Reply With Quote
Old 08-18-2012, 08:46 PM   #3
prof_fate's Avatar
Many have hollow back bumpers that may hold the cheapie hoses. If you get a good hose they won't fit.
I have a rubbermaid container that seals well and keep the hoses in there (one for main dump and i modd'd the cheapie to use with my bluboy). Keep it in the rubbermaid and in the compartment under our bed (blu boy too). No odors after 2 years of this so I'd say it's successful.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 08-18-2012, 09:10 PM   #4
Thanks for the quick replies. I am picking up my TH this coming weekend about 200 miles away and camping the night before in my old TT. Trying to have all my ducks in row. I will pick up a tote which will be dedicated for the drain hoses.
Old 08-18-2012, 09:47 PM   #5
Taranwanderer's Avatar
I don't agree with this statement--first off, what do you consider a "cheapie" hose? I bought my TT and it had a cheapie hose stored in the back bumper, but after 2 trips out I bought a RhinoFlex hose, then a second one for reaching from the galley tank to the drain, and they both fit (compressed) in my bumper. I also bought a plastic tool box and mounted it to the top of the bumper on one side to hold the coupler for hooking them together, the drain adapter, clear elbow, etc. I don't want any of that stuff stored anywhere near the other things I store in the outside compartment (I only have one outside compartment, the rest of the Salem's storage is inside, and that's also out of the question.) I wouldn't consider RF hoses cheapie, and they fit well. Shop around...
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 08-18-2012, 10:00 PM   #6
GASPEDDLER's Avatar
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 08-19-2012, 12:13 PM   #7
prof_fate's Avatar
That blue tote is what I use.
As for keeping the hose inside the bumper - while I've not done it's because when I asked about it I was told - the hoses will be damp when you are done with them and bumpers are metal - you will (eventually) get rust. This rust will then act like sandpaper we you push/pull the hoses in and out. The hose included with most campers is way cheap and thin and won't last long so I bought a rhino. While the hose is the same diameter the couplings are way larger, and it included caps so the nasty stays inside - no smells. the blue boy is also air tight so no smells.
But if what you're doing works for you keep it up.
2011 Grey Wolf 28BH
Old 08-19-2012, 12:24 PM   #8
bob213's Avatar
I mounted a 6" vinyl square fence post on top of my bumper. Glued a post cap (with holes drilled in it for drainage) on one end and another on the other end with a hinge, thumb screw and leash. All my hoses with connectors fit in it. It's smooth inside and won't rust. It works well for me. Clear connector and Y connector I store in a small plastic tote.
bob213 is offline   Reply With Quote
Old 08-19-2012, 01:17 PM   #9
Terier's Avatar
Many hoses that comes in the dealer starter kit I would consider cheap. Mine was thinner than the Rhino hose I replaced it with.
Until I found the right container for my use I used a heavy duty trash bag. My bay doors are pretty small and many of the containers I tried were just a tad too large to fit through the door.
I find the length I needed that would fit at Rite Aide and I paid a lot more than I wanted but at least now the hunt is over.
Old 08-19-2012, 04:34 PM   #10
Well, the reason I was asking is most toy haulers do not have a rear bumper because it would interfere with the ramp door. Some of the manufactures build in a storage for the drain hose similar to the vinyl square fence post mentioned by bob213. I have been using a round 8" pvc on my last TT and will probably use it again on this one after I find a suitable mounting area under the frame. Thank you to all with your replies.
