Old 07-03-2015, 07:32 AM   #11
All great suggestions. Something i will be shopping for in the near future.
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 07-03-2015, 08:11 AM   #12
Canadian Member
itat's Avatar
Originally Posted by Taranwanderer View Post
If you're going to go the DIY route, I would NOT use PVC as the guy from that link did. PVC should not be used for "suppy" water, only for "drain" or "waste" water. There's chemicals in PVC that can leach out of the pipe and into your drinking water, especially if the water has a lot of contact time inside the accumulator. Use CPVC.
Carry on...
Municipalities all over North America and Europe use PVC pipes to distribute water to homes so it's completely safe for drinking water.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 07-03-2015, 09:21 AM   #13
WolfWhistle's Avatar
Cold water plumbing in most Florida homes were white PVC with the hot water CPVC. Plumbers now either use CPVC for both cold and hot or PEX. Not becase pvc is banded or bad, because its easier.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 07-03-2015, 11:10 PM   #14
Taranwanderer's Avatar
There are arguments for and against, and plumbers on both sides of the issue.
From "Todayshomeowner.com:"
"Plastic pipe such as PVC (polyvinyl chloride, used for cold water only), and CPVC (chlorinated polyvinyl chloride, used for both hot and cold water) have been around for years, and both are approved for use with drinking water. Neither can be described as environmentally friendly from a production or recycling standpoint, however, and the glue used to join them together contains some strong solvents as well.
There is some concern about the leaching of chemicals that can give water a plastic taste, though the taste usually improves after a few months. Safety issues are mainly considered a concern in PVC pipe that was manufactured before 1977. While Iíve not seen any compelling evidence of the health risk of drinking water from PVC or CPVC plumbing, there is always the possibility that something will turn up in the future."
Back to your regularly scheduled program.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 07-04-2015, 09:29 AM   #15
Dogs drink from ditches, and look; they live to around 15 years.... or more!
Compounds of Chlorine in very small concentrations, is the least of my worries. I'm almost 70, so anything past that is gravy!
Somethings going to kill you. No one gets out of this alive anyway.
I think they need to remove ALL warning labels from everything and let nature take its course.
Old 07-04-2015, 07:19 PM   #16
Good health is just the slowest rate of dying.
breezyhillfarm is offline   Reply With Quote
Old 07-04-2015, 07:40 PM   #17
mark0224's Avatar
I put in the shurflo because I didn't have enough room to add anything bigger the pump still comes on almost as much but it is quieter because you don't get the hammering. It also makes the flow smoother you don't get the pressure fluctuation.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
water
