Old 06-30-2015, 07:04 PM   #1
Water Accumulator
Does anyone recommend a specific brand/model for a Water Accumulator? Looking to do this mod but I have only seen a picture from Dave961 when he installed one on his 27hfs (and can't see the brand/model in the pic...).
Thanks...
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 07-02-2015, 03:40 PM   #2
At first I didn't know what an water accumulator was I just had to look it up. seeing it now i want too install one too my water system as it knocks like crazy. I also have the 27hfs. It appears to me it hooks up right after the pump. Amazon has them for around $35
Berjr1 is online now   Reply With Quote
Old 07-02-2015, 03:44 PM   #3
Here is a DIY one
RV DIY Water Accumulator | ModMyRV
Old 07-02-2015, 06:28 PM   #4
WolfWhistle's Avatar
SHURflo Accumulator Tank RV Camper - $35.59
I'm not crazy about Adventure RV, but this is the model I have
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
WolfWhistle is online now   Reply With Quote
Old 07-02-2015, 06:48 PM   #5
Berjr1 & WW,
Thanks for the suggestions.
Old 07-02-2015, 08:33 PM   #6
2014 XLR 27HFS
I got it from Amazon, Steve. As Berjr1 says, $35.
Dave & Audrey
dave961 is offline   Reply With Quote
Old 07-02-2015, 11:08 PM   #7
Taranwanderer's Avatar
If you're going to go the DIY route, I would NOT use PVC as the guy from that link did. PVC should not be used for "suppy" water, only for "drain" or "waste" water. There's chemicals in PVC that can leach out of the pipe and into your drinking water, especially if the water has a lot of contact time inside the accumulator. Use CPVC.
Carry on...
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 07-03-2015, 05:29 AM   #8
The one I bought allowed me to take off the cold supply line to the outside "shower" valve and screw those lines to the accumulator (in series) without using anything other than a standard old fashioned pair of pliers that let me snug up the plastic nuts. Kind of hard to get to and I couldn't get it tight enough with fingers alone. Nothing else to buy. It doesn't matter what line its on, just needs to be the cold water side. I did screw on a tyrap mount and used a tyrap. Also, check the air pressure before turning the water back on.... its in the instructions. Works well.
Old 07-03-2015, 06:33 AM   #9
This is what I bought http://www.homehardware.ca/en/rec/in...Ntt=water+tank (you can find it cheaper than this site) it is larger than a shurflo and works great if you have the room.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 07-03-2015, 07:00 AM   #10
Tiny (Accumulators) help a Tiny bit in regards to (hammering)! Find a location where a (Large Accumulator) 3-5Gal.will fit! This can be Teed in(Anywhere) in the Cold water pressure side! This will give you (All night Toilet/sink operation Without the Pump (Instantly Running) Smooth constant flow Showers and more Water capacity! NOTE-Place a S/O valve on the outlet of the Accumulator for (Winterizing)! Lowes or HD have them. Youroo!!
water
