Old 10-12-2017, 04:43 PM   #1
Water heater
This is something I should know having had my XLR 27hfs for a season and a half. But I don't. I noticed an on off switch on my Suburban hot water heater. I've always ran it on propane. Does that switch mean that I have an electric option or does this switch just turn on the electric pilot. It's been in the on position since I bought the trailer. Thanks in advance. I get great advice and tips on this forum. It's saved me tons of money and headaches.
Bnrc73 is offline   Reply With Quote
Old 10-12-2017, 04:47 PM   #2
Just as confused as you
Scrapper's Avatar
The switch is for the electric heating element. If you had the RV hooked to ac power at any time without water in the heater, the element is burned out.
Richard & Jill
Old 10-12-2017, 05:15 PM   #3
Gumpster808's Avatar
Don’t feel bad we were told ours was propane only then I found that switch as well. In our car we had to two things to actually switch to electric - aside from making sure it was full - flip that switch to on as well as close the breaker inside.
If you have both and the breaker is off you may not have burned it out. If the breaker is on and did the items listed in the above post it is probably burned out.
They go pretty quick when no water on electric heating.
2014 3051S - First RV for us
Gumpster808 is offline   Reply With Quote
Old 10-12-2017, 06:17 PM   #4
wmtire's Avatar
Yes, if you have the Suburban brand water heater that has an electric heating element, this is one item that dealers fail to properly explain many times.
We keep a very detailed user guide here at this link:
http://www.forestriverforums.com/for...ore-36197.html
Hope it helps
2011 Flagstaff 831 RLBSS
Old 10-12-2017, 10:42 PM   #5
Hope it helps
Great article. Thanks
heater, water, water heater
