Old 05-28-2013, 09:52 AM   #1
water heater
How do I know if I have gas and electric for the water heater? Or do I just electric? I thought I had both gas and electric to heat the water.
Martins5547 is offline   Reply With Quote
Old 05-28-2013, 10:04 AM   #2
TURBS's Avatar
First of all open the outside panel and tell us the make and model.
Turbs
Old 05-28-2013, 10:06 AM   #3
TURBS's Avatar
This is a suburban gas/electric model.
Name:	7441_suburban front on closeup.jpg
Old 05-28-2013, 10:08 AM   #4
Herk7769's Avatar
If you have a large black round plastic thing behind the burner (and a small black switch) like in the first photo, you have both.
If your heater looks like the second photo, it is gas only.
Name:	Water Heater Outside.jpg
HAM CALLSIGN - KC3FFW
Old 05-28-2013, 01:30 PM   #5
It is the suburban gas/electric model like in the very first photo. So.... how do i know if both gas and electric are being used at the same time for faster hot water recovery? The switch inside is set to on.... is that all that needs to be done?
Old 05-28-2013, 01:35 PM   #6
Herk7769's Avatar
With water in the tank!, the little black switch on the outside controls the AC system. The switch inside (with the light) controls the 12 volt/propane side.
They are two independent systems with only the water in the tank being common. They can be used alone or together.
Name:	Rocker Switch.jpg
ID:	31552   Click image for larger version
ID:	31553   Click image for larger version
ID:	31554   Click image for larger version
Name:	AC diagram.jpg
Old 05-28-2013, 01:38 PM   #7
wmtire's Avatar
This question comes up a lot. This link below expounds somewhat on Herk's great post.
http://www.forestriverforums.com/for...ore-36197.html
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 05-28-2013, 01:49 PM   #8
I'm upgrading my basic propane model (SW6P) to the propane/electric model (SW6DE). It looks like I have the 3 wires for the 12V switch/light that are capped off in the heater compartment. I assume they run to where the 12V switch/light would be located in the coach if it had come with the direct spark option. Any idea where that would be on a 2004 Sandpiper Sport? By the battery/grey/black water indicator panel?
yzjim is offline   Reply With Quote
Old 06-05-2013, 02:20 PM   #9
For info, the upgrade was successful. The 3 wires that were capped off in the water heater area do run to the water/battery indicator panel area and were coiled up behind the wall with electrical tape on the wire ends. I did have to buy the 12V switch/light because it doesn't come with the water heater.
Old 06-08-2013, 03:47 PM   #10
Phat Phrog
RVChick's Avatar
Thank you Herk for that info!!! We have ours set on both and I always worry if that was ok. It does an amazing job heating water!!
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is offline   Reply With Quote
