Old 09-19-2016, 07:28 PM   #1
roguepra's Avatar
water pump electrical help
2016 27hfs, when the pump comes on while running on Batteries the whole trailer shuts off and on as if a circuit breaker is blowing and resetting. is there a main breaker to check for this? i thought i would check that first before looking into a faulty pump....any ideas??? thanks steve
2016 XLR 27hfs
2014 Tundra SR5/TRD 5.7 Firestone Airbags
Blue Ox WDH
2015 Roadglide spec
2012 switchback mechanic..(wife's)
roguepra is offline   Reply With Quote
Old 09-19-2016, 07:32 PM   #2
Flybob's Avatar
Check battery voltage and battery ground wire. A loose or dirty connection can cause a voltage drop.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 09-19-2016, 08:09 PM   #3
roguepra's Avatar
thanks i will check that first
2016 XLR 27hfs
Blue Ox WDH
2015 Roadglide spec
Old 09-19-2016, 08:34 PM   #4
Bluepill's Avatar
Battery could also be bad or badly discharged.
Do you have the problem when on shore power?
2008 Itasca Meridian 37H
Old 09-21-2016, 09:26 AM   #5
Roguepra...you haven't given enough info. Does it do it on both battery and shore?
otisite2016 is offline   Reply With Quote
electric, electrical, pump, water, water pump
