Old 01-10-2016, 08:15 PM   #1
mark.g's Avatar
What are these hoses near the front axle?
I was wondering if anyone could shed some light on what these two hoses are. One is blue pex and capped shortly after exiting the underbelly, the other is black. It is not my fresh water drain/overflow, those are behind the axles. These two in question are between the first two axles on the roadside of the RV. Any help would be appreciated. Thanks!
Name:	2016-01-10 19.09.41.jpg
2016 XLR Thunderbolt 415AMP
-Progressive Industries EMS-HW50C, SteadyFast Stabilizers
2005 Chevrolet Silverado 3500 6.6L Duramax
-Hillsboro Flatbed, Dakota Hills Truck Defender Aluminum Front Bumper, S&B Cold Air Intake, AirLift Load Lifter 5000 Ultimate, VIAIR Medium Duty Onboard Air System,
mark.g is offline   Reply With Quote
Old 01-10-2016, 08:27 PM   #2
Oklahoma Proud
MillerTime's Avatar
Low point drain maybe and a refer drain maybe?
Old 01-10-2016, 08:31 PM   #3
mark.g's Avatar
Low point drains are at the front of the rig, fridge has no water plumbed to it.
Old 01-10-2016, 08:33 PM   #4
The capped one is the water tank drain. The open one is the water tank vent. You have two fresh water tanks. These are for the second.
Karl4Cat is offline   Reply With Quote
Old 01-10-2016, 08:35 PM   #5
Homebrew's Avatar
I have a fresh water overflow in the same area on my 300x12.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 01-10-2016, 08:37 PM   #6
Oklahoma Proud
MillerTime's Avatar
Hmmm. I don't know unless it needed a second low point drain for cold water for some reason.
Edit. I see someone answered. Thats cool having an h2o heater drain. You would think they would use red pipe though.
Old 01-10-2016, 08:40 PM   #7
mark.g's Avatar
Karl,
If I have two fresh water tanks how does one fill the second one? I was only aware of one, towards the rear which have separate drain/vent than the ones pictured.
Old 01-10-2016, 08:45 PM   #8
Originally Posted by mark.g View Post
Karl,
You have two tanks centered over your axles with separate drains and vents. The fill line hits a T fitting at the first one and fills both at once.
Old 01-10-2016, 08:47 PM   #9
mark.g's Avatar
Gotcha. Sure would be nice if we had more developed manuals that covered these rigs in depth with what is what and where. But I suppose that would limit dependence on dealers for repairs. Thank you all!
Old 01-10-2016, 08:47 PM   #10
No problem bud. Glad to help.
Old 01-13-2016, 05:33 PM   #11
Oh what is this?
It should be just a freshwater vent or overflow
Hope this helps Happy camping
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
axle
