Old 02-12-2016, 07:03 PM   #1
Homebrew's Avatar
What compressor do you bring camping?
Looking into a good air compressor for my XLR and motorcycles.
What brand and model do you use for your TH and motorcycles ?
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 02-12-2016, 07:17 PM   #2
Canadian Member
This PORTER-CABLE CMB15
http://www.amazon.com/gp/product/B00...dp_o_pd_nS_ttl
Or this Viair 40047 400P-RV
http://www.amazon.com/gp/product/B00...dp_o_pC_nS_ttl
Old 02-12-2016, 07:48 PM   #3
Or this .......been using this one for a few yrs. .......
Unencumbered By The Thought Process
tande is offline   Reply With Quote
Old 02-13-2016, 06:48 AM   #4
Homebrew's Avatar
Link did not work
2014 Ram 3500 DRW
Old 02-13-2016, 07:35 AM   #5
I bought this one:
Amazon.com: Viair 00088 88P Portable Air Compressor: Automotive
along with this:
Amazon.com: Viair (00016) 6' Portable Compressor Air Extension Hose: Automotive
This hooks directly to the battery with clips because it is a heavier duty model.
Les & Heidi Kramer
2021 Jayco Melbourne 24L
Olmsted Township, OH
cpd1343 is offline   Reply With Quote
Old 02-13-2016, 07:39 AM   #6
nomad297's Avatar
I keep a Porter Cable 120 volt 6 gallon pancake compressor on the truck as well as a VIAIR 450P 12 volt. Both have served me well.
Bruce
Old 02-13-2016, 08:34 AM   #7
northstar1960's Avatar
since i don't care for oil less compressors i use the husky 3gallon 120 v . not much help without 120 but with the gen that's not an issue . also have a small 12 volt for the air bags and such
northstar1960 is offline   Reply With Quote
Old 02-13-2016, 09:01 AM   #8
geezer with gadgets
757Dave's Avatar
Originally Posted by Homebrew View Post
Link did not work
Worked for me...
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 30
757Dave is offline   Reply With Quote
Old 02-13-2016, 09:29 AM   #9
ferguson65's Avatar
I picked this up. Found it on sale for $109. Good reviews. Paired it with a 35 foot Flexzilla air hose. No other hose compares.
Shop Kobalt 1.5-HP 3-Gallon 155-PSI 120-Volt Hot Dog Portable Electric Air Compressor at Lowes.com
Don't have a gen yet so it won't be much help on the road, but good once in camp. It has a low profile and doesn't fall over like the pancake compressors. Actually have yet to try it, bought it to blow out the water lines for a specific trip but had to cancel.
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
Old 02-13-2016, 09:40 AM   #10
If you have room, THIS ONE from Harbor freight is a good value.
$59.99 regularly but they often have them in the sales flyer for $39.99.
I also carry a portable 12v jumper that has a small 12v compressor built in.
Similar to THIS ONE from HF but a different brand.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 02-13-2016, 09:46 AM   #11
ferguson65's Avatar
One thing to remember when looking at compressors is the CFM rating. Lots of the little ones have really pathetic ratings, which means they will take forever to do anything. In the class of inexpensive little compressors that Kobalt I posted has a CFM rating of 2.6 at 90 PSI. I couldn't find anything in a similar size with more CFM for the money.
2013 F350 dually
Old 02-13-2016, 09:54 AM   #12
davel1971's Avatar
your correct, but CFM rating isn't too important for tire inflating. More so for trying to run an air powered tool. 12 volt compressors will have lower ratings, but you don't always have 120 volts available. Only good at home or the campsite. Worthless on the road, since most of us don't carry generators.
David & Lynn
Old 02-13-2016, 11:12 AM   #13
Islander's Avatar
I bought this 12 volt compressor years ago to have as back up for traveling.
Now that I have replaced the 5th wheel pin box with an Trail-Air Tri-Glide
I have it ready for use in the front storage compartment along with a 12 volt outlet...quick and ready for the Air-Bag.
It is supper handy, light, compact, economical and does the job very well...even the truck tires @ 65 ~ 70.
I also adapted the hoses with quick disconnect and carry a 100ft hose for doing all the truck & trailer tires.
Picture & Specs.
12V Direct Drive Digital Compressor inflates to a maximum of 100 psi
Inflates an R15 size tire from 0 to 30 psi in about 3 minutes
Three LED worklight makes it easy to locate tire valves when working in the dark
Auto shut-off feature stops inflation when desired pressure is reached.
Hope this helps
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 02-13-2016, 12:47 PM   #14
3 gallon Sears 120 volt. Very handy.
Harkerr is offline   Reply With Quote
Old 02-13-2016, 01:03 PM   #15
ColoradoRick's Avatar
We have a Vaiar we bring camping (plugs onto the truck battery). I made a 25-foot extension power cable so it would reach back to the RV tires while hooked up. It's very small but is powerful, even has no problems with the big truck tires.
For the house, I have a small 3-gallon compressor I picked up at Harbor Freight.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 02-13-2016, 01:13 PM   #16
Can this one be regulated to also use when blowing out water lines when winterizing?
toddlafond is offline   Reply With Quote
Old 02-13-2016, 02:51 PM   #17
Always Learning
I carry and use a Viair 450P after talking to them about what I need.
Old 02-13-2016, 03:02 PM   #18
Lowe's Air Compressor
Same here. We never go camping without it. Before our TT, we owned a diesel pusher, wide body and used this for checking 100+lb pressures and it always kept everything right. Allowed me to sleep nights.
gfarmcafe is offline   Reply With Quote
Old 02-13-2016, 03:15 PM   #19
LLVanB's Avatar
Kobalt
X2 on this one. Good price, light weight, low profile, and higher cutout pressure. Resides in my basement 365.
LLVanB is offline   Reply With Quote
Old 02-13-2016, 03:29 PM   #20
poofam's Avatar
What I use
I have a converter on my camper. Select Language​
Quick Order
[COLOR=#FFFFFF !important]0 [/COLOR]
Sign Up for Special Offers:GO
  • Home/
  • Hitachi EC89 4 Gallon Air Compressor (Reconditioned)
Condition: Grade A
$129.95
Qty:
ADD TO CART
UPC Code: 717709015173
IN STOCK
246 Review(s) | Add Your Review
Click here for C Grade$ 101.96
View parts for this product
Description
The new EC89 twin stack compressor, which weighs just 57 pounds, has an oil-lubricated cast iron pump and 13 Amp direct-drive induction motor for long life. And with its all metal inner construction and fan, you can trust that it's built to last.
[/COLOR]
Customer Service
About Big Sky Tool.com
Shop With Us
Follow Us
  • VISA
© 2016 Big Sky Tool Store. All Rights Reserved.
poofam is offline   Reply With Quote
camping
