Old 02-13-2016, 10:04 PM   #31
Play Harder's Avatar
I use a Ryobi 18v portable air compressor works great has set psi feature and forget inflates to set psi and turns itself off - and fast fill for air mattress - yes it not very fast for a car tire or RV tire if empty but work fine for motorcycle - but if only topping off or in an emergency work great to 120 psi - have used it for 0ver 2years now and is small enough I never leave home without itClick image for larger version
Name:	ImageUploadedByForest River Forums1455422665.913421.jpg
Get out and Play Harder😛
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015😊
2002 Chevy 1/2 ton Quadrasteer
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
Play Harder is offline   Reply With Quote
Old 02-13-2016, 10:53 PM   #32
Kenny kustom's Avatar
Originally Posted by doc73 View Post
Do you think nitrox.. Or better even trimix might make the trailer pull better since the helium will make it float and be lighter 😨
I use a kobalt brand 120 compressor. I always have at least one geni with me.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Lol.
Whatever floats your boat.
I have my gas blender ticket.!!
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 02-14-2016, 09:35 AM   #33
Originally Posted by Homebrew View Post
Looking into a good air compressor for my XLR and motorcycles.
What brand and model do you use for your TH and motorcycles ?
I use a Ryobi One + 18 volt compressor. I have a couple of 18 volt tools I use and all use the same batteries. Ryobi makes good quality tools and the one + system is available at Home Depot.
The compressor has a setting you can adjust so I set it to 50 pounds, hook it to the tire and turn it on. When the proper pressure is reached it shuts off. I use it for my truck tires and for blowing water lines when necessary also. I always have a spare battery on charge so a dead battery isn't an issue. It is also lighter in weight than most compressors are.
I should have read all the posts. Ssame one as shown above.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 02-14-2016, 09:54 AM   #34
Ford Idaho's Avatar
I have one from Sears.
Their website says no longer available....
Old 02-14-2016, 08:02 PM   #35
Homebrew's Avatar
Thanks for all the suggestions. I'll be looking into a 120v type since we have a generator built into the 5th wheel and a inverter built into the truck.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 02-14-2016, 09:38 PM   #36
I would use a 12volt.
Unless you have a really, really large inverter in the truck.
2016 Sabre 36QBOK
Old 02-18-2016, 09:44 AM   #37
So look into the Ryobi system. Also get the 1/2 " I'm[act. Plenty of power to remove lug nuts on your tires and to run the rear stabilizers in and out.
With your generator nd inverter it would be easy to keep your batteries charged. Take a look at all the things you can run off of the Ryobi One+ batteries. Not a whole lot you can't do with it.
Search Results for¬*ryobi one ¬*at The Home Depot
I love their system and use it around the house all the time.
Jim
George Bernard Shaw
Old 02-19-2016, 06:44 AM   #38
ChibullsAN's Avatar
Jim
X100 !!! I take that 18v ryobi compressor everywhere.
2018 Rockwood Signature Ultralight 8329SS
ChibullsAN is offline   Reply With Quote
camping
