03-15-2015, 07:33 PM
What size TV
wondering how big a tv i can put in the 29xlr . don't know how much weight the wall stud can hold . weight between a 32 and 42 is not all that much
03-15-2015, 07:53 PM
As long as you mount to the studs, it should hold a 42" no problem. You could probably go up to a 46" if you got creative with the mount.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
03-15-2015, 08:17 PM
Great it's only 5lbs difference from a 32 to 42 . and much prefer the 42 and now o won't need to buy another tv
03-16-2015, 06:41 AM
FYI NS, the TV wall in living room has a full 2x6 on the flat centered on that wall, between the sliding doors floor to ceiling. That would be the same stud in the master bedroom don't know about the garage. Just get the mount centered within that 5-1/2" and watch screw / lag length. I would say a 46" would work great... its all about the strength of the mount. You might want to consider taking down the TV while traveling. I leave mine up but have cleats on the ceiling and support with straps to take the weight.
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
03-16-2015, 07:48 AM
What size TV
In a couple weeks - I'll tell you exactly where the studs are in the M bedroom and garage -- w photo's --- I have X-Ray vision 😜😜
Any other request to see what in any wall? Let me know
Get out and Play Harder😛
2015 XLR Hyper Lite 29hsf - loaded on order
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
03-16-2015, 08:15 AM
Play Harder,
Just checking in on the "process" for the delivery of your new TH. Have you been given updates on the build of your new TH thru out the build? Do you have conformation that on 3/23 (if I remember right...) you will be able to pick up your new TH?
I'm just so excited to get my new TH, I want to make sure I have realistic expectations for my delivery...
Thanks...
03-16-2015, 08:42 AM
RV wholesale has been in contact w me- and I'm supposed to get another update today
2008 Can Am Spyder
03-16-2015, 08:58 AM
Perfect...
03-16-2015, 10:23 AM
Thanks for the info . I think I'll keep my 42" and look for a good mount and plan on straps when in motion , or one that will allow me to remove TV for travel , the TV uses about 90watts add on that a dvd player small wattage use , but the dish hopper is a bit more . Glad i got the 4000/3500 champion . my first task will be making it quite but for 399 just could not pass up
03-16-2015, 03:33 PM
I just lean mine against the wall
Hyper Lite was sold
03-16-2015, 03:40 PM
Where does the TV end and the wall start? Looks like all TV to me. Now that will make for one great rainy day camping.
2005 Winnebago Adventurer 38R
Workhorse 8.1/Allison Transmission
Old 2005 Forest River Cherokee Lite 28A
03-16-2015, 05:17 PM
Perfect size --
Just got call from RV whole sellers - vin # is in and scheduled pickup on 24th confirmed at 10am -😄😄😄😄😄😄😄😄😄😄
2008 Can Am Spyder
03-16-2015, 07:48 PM
Do you have to lie on your side to watch it?
03-16-2015, 08:03 PM
Play Harder,
Congrats on the good news....
03-17-2015, 05:54 AM
Perfect size --
2008 Can Am Spyder
Yeah! And a big Hooray!
Hyper Lite was sold
03-17-2015, 06:13 AM
Its just me being silly. I did see a home automation installer attach some kind of heavy duty swivel mount sideways and didn't realize it until he tried to attach the very large flatscreen. Bad thing was several tradesmen were there to laugh "with" him!
Hyper Lite was sold
03-17-2015, 08:54 AM
I do plan on putting in one of those swing down ceiling TV mounts for better viewing from the recliners - hopefully I can find something good to mount bracket to - once I X-Ray the ceiling 😃
2008 Can Am Spyder
03-17-2015, 09:25 AM
[QUOTE=Play Harder;808602]I do plan on putting in one of those swing down ceiling TV mounts for better viewing from the recliners - hopefully I can find something good to mount bracket to - once I X-Ray the ceiling 😃
The ceiling has wood trusses. I wouldn't trust on truss to support TV and mount. Maybe you will figure out a way. Mine is on a swing out and tilt mount from Wally world. I can aim it directly at the sofa. I have straps to the ceiling to protect the TV while on the road... hmmm.... screwed to a single truss.
Hyper Lite was sold
03-17-2015, 09:55 AM
What size TV
That why I plan to X-ray the ceiling and find a good location to cut a hole and install a bracket between 2 trusses to mount the ceiling TV bracket to and a painted matching aluminum cover - and hopefully I can wallfish the wires to that location while in the ceiling too.
This will not happen within the first 45 days but expect by the of summer --
2008 Can Am Spyder
03-17-2015, 09:59 AM
[QUOTE=WolfWhistle;808637]
WolfWhistle,
Do you have any pictures of this setup? I may have seen it in the "what have you done...." post but I'm not sure if it was yours or not.
Thanks...
