Old 03-15-2015, 07:33 PM   #1
northstar1960's Avatar
What size TV
wondering how big a tv i can put in the 29xlr . don't know how much weight the wall stud can hold . weight between a 32 and 42 is not all that much
northstar1960 is offline   Reply With Quote
Old 03-15-2015, 07:53 PM   #2
vinmaker's Avatar
As long as you mount to the studs, it should hold a 42" no problem. You could probably go up to a 46" if you got creative with the mount.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 03-15-2015, 08:17 PM   #3
Great it's only 5lbs difference from a 32 to 42 . and much prefer the 42 and now o won't need to buy another tv
Old 03-16-2015, 06:41 AM   #4
WolfWhistle's Avatar
FYI NS, the TV wall in living room has a full 2x6 on the flat centered on that wall, between the sliding doors floor to ceiling. That would be the same stud in the master bedroom don't know about the garage. Just get the mount centered within that 5-1/2" and watch screw / lag length. I would say a 46" would work great... its all about the strength of the mount. You might want to consider taking down the TV while traveling. I leave mine up but have cleats on the ceiling and support with straps to take the weight.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 03-16-2015, 07:48 AM   #5
Play Harder's Avatar
What size TV
In a couple weeks - I'll tell you exactly where the studs are in the M bedroom and garage -- w photo's --- I have X-Ray vision 😜😜
Any other request to see what in any wall? Let me know
Get out and Play Harder😛
2015 XLR Hyper Lite 29hsf - loaded on order
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
Play Harder is offline   Reply With Quote
Old 03-16-2015, 08:15 AM   #6
Play Harder,
Just checking in on the "process" for the delivery of your new TH. Have you been given updates on the build of your new TH thru out the build? Do you have conformation that on 3/23 (if I remember right...) you will be able to pick up your new TH?
I'm just so excited to get my new TH, I want to make sure I have realistic expectations for my delivery...
Thanks...
stevejd235 is offline   Reply With Quote
Old 03-16-2015, 08:42 AM   #7
RV wholesale has been in contact w me- and I'm supposed to get another update today
2008 Can Am Spyder
Old 03-16-2015, 08:58 AM   #8
Perfect...
Old 03-16-2015, 10:23 AM   #9
Thanks for the info . I think I'll keep my 42" and look for a good mount and plan on straps when in motion , or one that will allow me to remove TV for travel , the TV uses about 90watts add on that a dvd player small wattage use , but the dish hopper is a bit more . Glad i got the 4000/3500 champion . my first task will be making it quite but for 399 just could not pass up
Old 03-16-2015, 03:33 PM   #10
I just lean mine against the wall
