If your bearings have never been removed, cleaned and repacked, you should repack them. If you use the EZ LUBE feature BUT use a different type of grease that’s not compatible with what the factory or a PO used, it can cause serious issues. The other issue with bearing buddies etc, is that if you push too much grease into them they can push the rear seal out.
New bearings typically are around $50/ wheel, simply remove the old ones, choose your grease, pack and install. Make sure you make a note of the grease you used and buy an extra tube or 2 so you have it on hand.
If you take your camper to a dealer, and you repacked your bearings make sure you make it clear you do not want them to grease them as part of any “maintenance” routine.
John
People sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf.
99 F350 Dually 7.3L
