Old 03-10-2016, 07:25 PM   #11
WolfWhistle's Avatar
absorbed glass mat.
The cable / wire gauge has to be sized properly to match the length of the run... go to far on too light a gauge and you won't charge them properly... that is why the TV cannot charge a trailers batteries... too much voltage drop. AGMs can be damaged by charging at too high a rate, which isn't a problem since nearly all our rigs stay plugged in all the time. What I don't like about a sealed battery is you can't check with a hydrometer, which is the only way you know how the battery is doing and if equalization is needed and they are expensive. AGMs are a viable option if the positioning or location prevents normal maintenance or if they can't sit bottom down... or in the case of the OP, they are free!
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
battery
