Old 03-07-2016, 07:33 PM   #1
mark.g's Avatar
Where would you put these batteries
I acquired four GNB Marathon 155AH telecom batteries used for power backup systems as part of a package purchase recently. If I can find a place to put them it would give me over 600AH of battery available. The problem, they are 5" wide, 11.15" tall, 22" long, and come in at 119lbs each. Lots of battery without a clear location to install. They are sealed AGM with a 12 year service life with only 3 years of that gone so far.
My thoughts right now are to either find a location to install them on the rig itself, or use it as portable battery bank that I can connect to the rig as needed. The least desirable, I try to sell them to someone who has the space to put them in their home or RV solar project.
Thoughts?
Link to Battery Info: GNB Marathon M12V155FT 12v 155ah Front Access Telecom Switchgear AGM Battery TEL12-150F, TEL12-160F, M12V150FT, 12V155F
2016 XLR Thunderbolt 415AMP
-Progressive Industries EMS-HW50C, SteadyFast Stabilizers
2005 Chevrolet Silverado 3500 6.6L Duramax
-Hillsboro Flatbed, Dakota Hills Truck Defender Aluminum Front Bumper, S&B Cold Air Intake, AirLift Load Lifter 5000 Ultimate, VIAIR Medium Duty Onboard Air System,
mark.g is offline   Reply With Quote
Old 03-08-2016, 04:42 PM   #2
WolfWhistle's Avatar
Interesting M, wonder how the ah is rated? Battery makers play ah games, but probably not these Also very heavy.... hope they (4?) aren't on the tongue(?) ... don't know but in the telecom world, batteries are carefully maintained and might not like bouncing down the road. A heck of a battery none the less. We have batteries over 40 years old when I retired... babied them.
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 03-08-2016, 04:58 PM   #3
Kenny kustom's Avatar
I looked at the same type of battery.
I was told, they may not stand up to vibrations in an Rv.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 03-08-2016, 06:38 PM   #4
mark.g's Avatar
WW
I know the rating is on the battery, but I do not remember what it was off the top of my head. They're not on the RV at the moment. I am not even sure if I will use them due to the weight, but was curious what others would do if they had them. I essentially got them for free so its no skin off my back if I can't use them but figured since I have them I would at least look into using them.
Old 03-09-2016, 09:22 AM   #5
MG, I know I would use them. Even in my towable TH, I would figure out something. Then make darn sure my charger can be optioned for the required bulk charging voltage (14.8 - 15.0) and the occasional equalization routine; if you don't you won't get them charged and they won't last. IOTA makes such a charger as does the charger in the Magnum Inverter, I just ordered (with monitor). I have two 230AH GC2 and might get two more; but adding two more on the tongue, isn't desirable, not to mention the PV panels are located more than 30 feet away. I wonder if the person who says that they won't take the bumps, might have an agenda... I don't know, but considering the price and if the weight / space is doable, I would use them.
WW
Old 03-09-2016, 09:28 AM   #6
i have to ask, What kinds of package purchase did these come with? sorry.. intrigued
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 03-09-2016, 10:37 AM   #7
mark.g's Avatar
I purchased a little 5x8 enclosed trailer a guy was using as a bugout trailer. He was trading up to a small travel trailer and didn't want to de-bugout the 5x8. Ended up with a Mr Heater buddy heater, one solar panel, the batteries, some MREs, and a few other misc. items.
Old 03-09-2016, 10:49 AM   #8
mark.g's Avatar
WW
When I do get around to upgrading my batteries I will be also installing a better charging system to ensure maximum life from the batteries. Whether it be these bad boys or something else. Trick is just finding a spot without adding them to the pin. Perhaps a box in the garage, or convert the dove tail storage box to a vented battery box. Alas, I will need more time than I have at the moment to do that level of upgrade/customization. Thank you all for the inputs!
Old 03-09-2016, 12:39 PM   #9
Thoughts?
I'd place them in the back of my 3500 1 ton tow vehicle, and spend some money on a proper charger and/or converter. Sealed AGM batteries and FLA batteries may have different charging requirements. Extra batteries would be a good idea if you boondock a lot.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 03-09-2016, 08:35 PM   #10
Happy Camper
I agree with DickiedooFlagman about finding the proper charger, etc...
I own an automotive repair/service business and had to upgrade charging & testing equipment to handle the different characteristics of the Absorbed Gas Mass batteries. They have benefits but can not be charged at a normal battery charger rate without possibly shortening the battery life.
Google it.
Johntgif is offline   Reply With Quote
battery
