Old 06-28-2016, 02:47 PM   #1
Willdogg
Winegard SK-SWM3 Help
I finally pulled the trigger for the Winegard Trav'ler Model SK-SWM3 for our 415 AMP. I plan on installing it myself and would like to know if anyone has done this on their TH and can you give me some advice or suggestions that may help to ease this install. I would like to know too if a plate is needed or is the roof stable/strong enough to just install as is. The instructions mentions nothing about a plate to mount the base on. Also can anyone give me advice about where the 1" hole should be drilled in the roof. Should I make the connection in the pass through to the satellite coax connection there? or try to drill the hole so it drops in behind the TV. any advice / tips is appreciated.
Thanks in advance!
willdogg is offline   Reply With Quote
winegard
