Old 11-19-2015, 10:55 AM   #21
WolfWhistle's Avatar
Your roo are you talking about the white scale on the water heater.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 11-19-2015, 11:04 AM   #22
No I am saying the (White Crud/Flakes/) that come Out of the Tank when you drain the Tank! Youroo!!
Old 11-19-2015, 03:25 PM   #23
Thought that was soap scum and maybe sink crud.
Old 11-19-2015, 04:41 PM   #24
Homebrew's Avatar
I always pump some pink stuff in the Black tank rinse line.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 11-19-2015, 05:07 PM   #25
Me too. I use the outdoor faucet to make it easy.
Karl4Cat is offline   Reply With Quote
Old 11-19-2015, 05:08 PM   #26
How in the world would Soap Scum get inside the Water Heater? Youroo!!
Old 11-19-2015, 05:11 PM   #27
Homebrew's Avatar
Great idea ! I'll try that next time.
I normally pump it in to the city connection and then pump some into the rinse line.
2014 Ram 3500 DRW
Old 11-19-2015, 05:23 PM   #28
I use the factory winterizing draw tube that's right behind my blue hose in the pic to pull in the antifreeze with my water pump. Winterize the rig then pump a bit into the black tank flush.
Old 11-19-2015, 09:12 PM   #29
Youroo I dont call mineral deposits from hard water crud... Its just minerals.. that's why I thought you were talking holding tanks. The deposits form on the heating element; then fall to the bottom of the tank. How the heck can these deposits get "downstream" into the water system when they're coming out of the HW tank while draining happily away? They really come out when i give it a shot of air with all faucets closed to further remove more water. You have to better explain how deposits on the bottom of the tank gets up into the water system. I don't see how that is possible.
WW
Old 11-19-2015, 10:45 PM   #30
Kilday4's Avatar
P
Mike & Kim Kilday
11' F250 6.7 SD
15' XLR 27HFS EP
Kilday4 is offline   Reply With Quote
winter, xlr, winterize
