Old 11-20-2015, 05:38 AM   #31
Originally Posted by WolfWhistle View Post
Youroo I dont call mineral deposits from hard water crud... Its just minerals.. that's why I thought you were talking holding tanks. The deposits form on the heating element; then fall to the bottom of the tank. How the heck can these deposits get "downstream" into the water system when they're coming out of the HW tank while draining happily away? They really come out when i give it a shot of air with all faucets closed to further remove more water. You have to better explain how deposits on the bottom of the tank gets up into the water system. I don't see how that is possible.
WW
Easy,Members have been given BAD Info about opening their Low Point Drains Before Bypassing the W/H! This Can/Does draw (White Crud) downstream! It will not show its Ugly Head until Spring when they ask,(Why is my Faucets running slow and the Screens are plugged with White Flakes)? You can call it (Minerals) if you feel better but to Me and Many others it is (White Crud) that comes out of the W/H Tank and runs on the ground or shop floor! If I were to buy a cup of Coffee and it had your (Minerals) in the bottom of the Cup,I would ask for My $$ back! Youroo!!
youroo is online now   Reply With Quote
Old 11-20-2015, 04:24 PM   #32
WolfWhistle's Avatar
Still say if its running out of the tank while the taps are closed it can't run toward the taps. You have minerals in your coffee just not chunks. What do you think plugs up coffee makers? If it could harm us, we would all be dead by now. :us-flag-waving
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 11-20-2015, 05:49 PM   #33
What happened to lined HW heaters? My last rig, a 2013 Road Warrior, had a lined tank and no sacrificial anode. Just a drain plug. Maybe a different brand than XLR uses?
Karl4Cat is offline   Reply With Quote
Old 11-20-2015, 07:35 PM   #34
I think Atwood uses a fiberglass lined tank ... so no need for a anode
Old 11-20-2015, 07:41 PM   #35
Yep, I think the RW had an Atwood tank. Better system. I really like the new option of Girard on demand HW. It would appear it's a drop in replacement for the current tanks. I'd love to upgrade it along with my genset to the EFI version... Time to go buy a scratch ticket...
Old 11-22-2015, 07:39 AM   #36
northstar1960's Avatar
As far as i know atwood uses an aluminum tank so no need for anode . much better then our suburban tanks and when my suburban tanks takes a dump it'll be replaced with an atwood
northstar1960 is offline   Reply With Quote
Old 11-22-2015, 07:54 AM   #37
nomad297's Avatar
This is accurate and I, too, would replace with an Atwood.
Bruce
Old 11-22-2015, 08:06 AM   #38
one could also increase in size from a 6 gallon to a 10 gallon same opening size with an atwood . i know in the xlr 29 there is enough room for the 10gal unit
winter, xlr, winterize
