02-22-2015, 10:49 AM
#21
Dazed & Confused
Originally Posted by gljurczyk
I would agree with turbs a good place to start and see the colors, Also WFCO convertors do not have a red led light up if I remember, I put a progressive one in and it will light red when blown or the fuse is pulled.
Hate to be a twit, but the converters does not have the LED blown fuse indicators, the distribution panel has them, including WF-8930/50 50 Amp Distribution Panel. BTW This panel can be used for either 30 or 50 amp services.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2020 Ram 2500 6.4L Crew cab 4WD, 4.10 Axel
02-22-2015, 02:01 PM
#22
Originally Posted by Tx_Rider
WolfWhistle,
I read in another thread that the WFCO distro panel will not show a "red" LED with an open circuit if there is no load or draw on it. I have only seen this information once so I am suspect of it's accuracy.
I know the flood switch is good because it powered the step light when it was hooked up incorrectly.
Now I am thinking a ground issue.
I need to go back to the RV and do some more process of elimination.
Tx, this is correct. On these WFCO panels, the circuit has to have a path to ground (like through a bulb) for the indicator to be lit. Turn a light off and pull that fuse, nothing; switch it on and pull the fuse it glows bright red. Its magic, I'm telling you
Grounding... I would think there are multiple ground points as well. ... like there are 6 bulbs. But, I'm only suggesting.
I would have to get out the step ladder and test from on of the floods... with a test light or multi-meter. Say, you did order the optional "bulb package" with your Thunderbolt, right?
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
02-22-2015, 02:13 PM
#23
If they are spoda be wired in line one to the other and a macadamia at the factory goofed the connection that would be an incomplete circuit,right
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
02-22-2015, 02:25 PM
#24
I do have the WFCO 8930 panel, it does have LED lights for blown fuses.
In addition, I switched the location from terminal #8 marked "floods" to a spare at terminal #13, switched wire and fuse, still nothing.
I will test a light as a process of elimination.
WolfWhistle, you may have a point, I might not have got the "bulb" option.
2015 Thunderbolt XLR 340X12HP
2019 Ford F350 KR, 6.7, CC, LB with B&W Companion
US Army Retired
02-22-2015, 11:03 PM
#25
Occam's Razor. The simplest answer is often the best.
02-23-2015, 06:48 AM
#26
You must be joking? all the money you pay for a trailer and you have to buy the optional bulb package? I can see if you wanted to upgrade to LED but no bulbs at all, truly you must jest? FR has gotten that cheap?.....
Coachmen M/H
Concord
2018 / 300 DSC
02-23-2015, 07:49 AM
#27
Yes Sir, surely I jest.
Breezyhillfarm, exactly.
Hyper Lite was sold
02-23-2015, 08:06 AM
#28
I just scanned this thread so if someone already said this- sorry....
I think a "fuse blown" red light would only come on if fuse is blown or
removed while circuit is ON.
IE- you have a light on. You pull the fuse (or it blows), the red LED illuminates to
indicate a blown fuse.
You don't have a light on. You pull the fuse, nothing happens....
at least that's the way I think they work.
You need a load on the circuit in order to get the fuse LED to illuminate.
IF your flood lights have a miswired open circuit or hidden switch that is off, that
means no load on the circuit and the fuse LED would not work.
Peace!
Dan & Rita D
02-25-2015, 07:10 PM
#29
Update:
I fixed the issue.
What are the odds that all the flood light and step light bulbs are bad?
Well, 100%. Sadly, all the bulbs except the front door step light were bad.
I know there will be some "I told ya So's" but, because of the location of the lights (access)and the odds of all the bulbs being bad, that wasn't my first check. They were all either milky white or blue in color, one even had a hole in it. No blown fuses though. I put in new bulbs coated in dielectric grease so I'll see how they hold up.
I did figure out what switch works what light.
On my particular model, the "flood" switch on the main panel only operated the front curb side flood light. The "step" switch operates the step light above the front and rear doors.
The switches next to the radio in the garage operate the rear and ramp flood lights.
Guess I'm a "Happy Camper" now.
US Army Retired
02-25-2015, 07:11 PM
#30
Update:
I fixed the issue.
good to hear.
TURBS
02-25-2015, 07:26 PM
#31
Told ya so .... even though I didn't .....feel better you got one
02-25-2015, 07:28 PM
#32
Lol i wonder who mentioned the bulbs?
Hmmmm who was it.....?
TURBS
02-25-2015, 07:36 PM
#33
TURBS
Wasn't it OC ????
02-26-2015, 07:25 AM
#34
I knew I had that coming.
US Army Retired
02-26-2015, 07:31 AM
#35
[emoji106] I knew I had that coming.
Lol carry on![emoji1]
TURBS
02-26-2015, 07:59 AM
#36
I love a happy ending and a good follow up msg so we get to know
"The Rest of The Story". (said in my best Paul Harvey voice)
Peace!
Dan & Rita D
02-26-2015, 09:54 AM
#37
Whats a wiring diagram? What do you mean about a red light when pulling a fuse. I think a fuse has to be blown to light the red light. I don't have step lights; is that factory? Do you have 3 switches just inside the front door? Several members have reported factory mis-wiring of these. But easy to fix. You didn't say if you checked the bulbs(?).
I won't say I told you so, but will show the first reply you got I am glad you got it and that you are humble enough to tell us what you found, I'm proud of you.
Sounds like someone wired them to 120vac... that's called flashcubes (remember those?)
Hyper Lite was sold
02-26-2015, 09:58 AM
#38
Maybe a different old coot, there's only one OC. Not him, but about everyone else....
Hyper Lite was sold
02-26-2015, 11:35 AM
#39
I was thinking post 17 has some merit!
02-26-2015, 12:23 PM
#40
OK so what about a wiring schematic. I realize that not every situation is simply a bad bulb. Why is it so painful to get the details of our build. Not everybody has a engineering degree in electronics and wouldn't necessarily understand it all but what about those of us that do?
It seems to me that the diagram should be included with the build and / or easily accessible via the web.... Hello it's 2015 and most modern platforms are pretty complex .....
2005 Dodge Ram Laramie, SRW
5.9L Cummins Turbo Diesel 24 valve
2013 Forest River Thunderbolt XLR 380 AMP
Cow Bell
2010 Star Motorcycle Stratoliner Deluxe
