Old 11-20-2015, 02:15 PM   #11
Play Harder's Avatar
CJ
Most likely the foam did not cure - or fill correctly allowing pockets of air and eventually will break due to low strength in those areas
Play Harder is offline   Reply With Quote
Old 11-21-2015, 12:56 AM   #12
CJ I did take X-rays of along both sides and top - top to bottom there are no supports in door
Get out and Play Harder😛
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015😊
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
Old 11-21-2015, 12:47 PM   #13
Dabmeb's Avatar
In other news, THESE ACTUALLY WORK?!?!?!?
Lol, I'm still waiting for my refund.
Dabmeb is offline   Reply With Quote
Old 11-21-2015, 07:16 PM   #14
northstar1960's Avatar
2008 Can Am Spyder
Correct . no supports in door and 0 proof otherwise . not even for the party door . A dealers say so means nothing
northstar1960 is offline   Reply With Quote
Old 11-21-2015, 08:09 PM   #15
trbomax's Avatar
This would explain why the edges of the plywood sheets are transferring thru the outside "gel coat finish" which (at least on ours) is painted.It does appear to flex when I run the electric golf cart on it.
trbomax is offline   Reply With Quote
Old 11-22-2015, 01:29 PM   #16
Lippert makes these doors for Forest River (and probably everybody else). My toyhauler door was spongy along the hinge line. It looked like the hinges were going to push through. I sent pictures to Lippert. They said it was water damage (one of the side pieces was loose on the door, i.e., not sealed) and replaced the door.
This pic shows where the side piece was moving when the door latch was operated.
Hinges are sinking into door
Hard to see - in the corner the flooor/door covering is bubbling up
andy29847 is offline   Reply With Quote
Old 11-22-2015, 01:42 PM   #17
It Doesn't appear to have any plywood in them . nothing but composite and Styrofoam and some fiberglass on the out side
Old 11-22-2015, 02:11 PM   #18
I believe that it is a fiberglass-luan plywood-foam-luan plywood-fiberglass sandwich.
Old 11-22-2015, 03:18 PM   #19
Well dang . I'll look for my sticker and see what it shows for materials
Old 11-22-2015, 03:18 PM   #20
R3Jones's Avatar
X-Ray photos of non-party deck door
Per the XLR GM there is no wood in the ramp door.
Wonder if that is a recent change.
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
2017 2500 Denali Duramax
R3Jones is offline   Reply With Quote
door
