Old 02-17-2016, 06:51 PM   #1
dwhit's Avatar
Location: Chicago, Rochester now GA/SC at Lake Hartwell
XLR 12vdc wiring available at fan/vent housings
I have the XLR Thunderbolt 415 with two Fantastic fans. I'd like to add two more. The garage has a small fan I'd like to replace, and the loft has just a vent that opens. Is 12vdc available in the loft opening? Is heavier wiring available in the garage fan opening? All I can see is 22ga wire for the tiny fan motor.
I ask as I replaced three passive vents in my class A with Fantastic fans. I didn't need near the a/c as before. The amount of air movement multiple fans offer is quite desirable. I did have to tap-off lighting fixtures to get heavy 12vdc for two of those fans. I'm wondering if I have to do the same with the XLR.
Anyone with knowledge in this area before I start cutting?
XLR 415AMP, F350 Lariat 6.7 DRW, three bikes, NRA Benefactors.
Heart issues-laid up for a spell
dwhit is offline   Reply With Quote
Old 02-17-2016, 09:40 PM   #2
chpence1's Avatar
No your asking for the impossible. ..... wiring specifications and or schematics don't exist.....
2005 Dodge Ram Laramie, SRW
5.9L Cummins Turbo Diesel 24 valve
2013 Forest River Thunderbolt XLR 380 AMP
Cow Bell
2010 Star Motorcycle Stratoliner Deluxe
chpence1 is offline   Reply With Quote
Old 02-18-2016, 08:49 AM   #3
dwhit's Avatar
Thanks CHPENCE1.
I thought I was addressing anyone who has been in these fixtures. When I added fans in my Damon the rear passive fan outlet had heavy 120vac wiring capped-off for the addition of an addt'l a/c unit. So I'm looking for that person who has already been there...done that. Someone has added a fan in these Thunderbolt fixtures and has seen in person what factory wiring exists.
Old 02-18-2016, 07:58 PM   #4
mark.g's Avatar
The wiring for the loft may be present as there is a power fantastic fan when the full rear bath option is added. The only way to be sure is to open things up and see if there are wires or not.
2016 XLR Thunderbolt 415AMP
-Progressive Industries EMS-HW50C, SteadyFast Stabilizers
2005 Chevrolet Silverado 3500 6.6L Duramax
-Hillsboro Flatbed, Dakota Hills Truck Defender Aluminum Front Bumper, S&B Cold Air Intake, AirLift Load Lifter 5000 Ultimate, VIAIR Medium Duty Onboard Air System,
mark.g is offline   Reply With Quote
Old 02-18-2016, 10:03 PM   #5
chpence1's Avatar
Funny
Cow Bell
Old 02-19-2016, 02:05 PM   #6
WolfWhistle's Avatar
On my 29hfs the wire gauge to the vents is probably 14ga and runs the maxair vents very well. I doubt there is wire that wasn't paid for but 4 screws and drop the vent trim will reveal much
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
WolfWhistle is online now   Reply With Quote
Old 02-19-2016, 06:16 PM   #7
XLR Production
Your garage fan can be replaced with a fantastic fan. You have 14ga wire up there. For the loft fan, if you can run a 14ga wire to the main A/C in the living room, you can pull power from there. I believe it is an orange and white wire. It's a constant hot at that location.
bulletbob is offline   Reply With Quote
Old 02-20-2016, 07:23 AM   #8
dwhit's Avatar
Thanks Bulletbob...I knew someone with knowledge would get back to me...now I can go up there with fans and tools w/confidence instead of hope and chance. Hurricane force winds in my 415 soon.
Old 02-21-2016, 04:20 PM   #9
chpence1's Avatar
It's a liability thing.
Cow Bell
fan, vent, wiring, xlr
