Old 08-22-2013, 02:49 PM   #1
Xlr 24hfs
Hello everyone. I am brand new to the forums and to camping for that matter. Never been much for sleeping in a tent under the stars with no comforts, but with this thing I am content.
I picked up a used 2013 XLR 24 HFS and love it. I have owned it for about a month and have used it almost every weekend since the purchase. I have a few questions and hoping you can help me out.
I have a 2013 Dodge 1500 Big horn, max tow 10,300, I am noticing that it pulls the trailer just fine, but I do get some sway. how do I determine what sway hitch and stuff like that to put on? I am going to be hauling 2 harleys in there, one is a street glide, 850 lbs and the other is a road glide 850 lbs. The person before me must have had a sway system on it, as there is mounts or something on trailer already
I have figured out the dump station procedures by reading some of the posts on this website and that is going well, but what do you with the fresh water can you just dump it or do you need to do that at the dump station? What is the proper etiquette?
Fresh water meter doesn't work, I have a warranty, but sounds like it will take time to fix, just not wanting to turn it in yet for that.
The spot for the TV seems really high, anyone else able to find a mount that would lower to a more acceptable level?
Cooking with both burners, the heat alarm goes off.
Shower curtain, everytime I take a shower and turn around the shower curtain follows me and pretty soon I am wrapped up in it like a soaped up tamale. Not a good visual
How often should you clean the outside and can I use a pressure washer to do that? Also same with the roof?
ID:	38435   Click image for larger version
ID:	38436   Click image for larger version
ID:	38437   Click image for larger version
ID:	38438   Click image for larger version
SIBELL is offline   Reply With Quote
Old 08-24-2013, 02:33 PM   #2
RFK
RFK's Avatar
I can help with some of the questions. We have a 27 hfs. A weight distribution hitch may solve the sway problem. I have the Blue Ox Sway Pro and have towed with two dressers inside without a problem. Sounds like you have the mounts for a WD hitch already on the RV Smoke detectors go off every time we cook inside. I think we're being told to go outside and cook. Ha ha. Sounds funny, but yes we cook everything outside now An electric skillet is perfect for breakfast I would not drain the fresh water at any campsite and draining it at a dump station might be tricky too. I let mine drain at home in the driveway But it sounds like you're enjoying your new camper and that's the most important part. Congrats !
Ray & Barb
2012 Sierra Duramax 2500HD 4 x 4
2013 Forest River XLR Hyperlite 27 HFS
2007 Harley Electra Glide Classic
RFK is offline   Reply With Quote
Old 08-24-2013, 04:12 PM   #3
Congratulations, I also have a 27 HFS and truly enjoy it. As far as a tow bar I have the EZ lift that was installed by the dealer at time of purchase. The sway control is the flat bar type and so far has worked just fine. I am a big guy and have not had a problem with the shower curtain,"YET". but ours bows outward at the top. I noticed one on-line at camping world that bows out ward to give more room. We cook outside most of the time, but have had our alarm go off when cooking inside.
I wash mine when ever it looks dirty. I use a soft brush and regular car washing soap. I have not cleaned the roof yet because I'm not sure the roof would support my weight.
Like RFK I wait until I'm home to drain the water tank.
John And Mary
2013 XLR 27 HFS
2013 CHEVROLET 2500 6.6 DURAMAX
Nights Camped 2012 (7) 2013 (33) 2014 (27) 2015 (34) 2016 (4)
Kaboom is offline   Reply With Quote
Old 09-14-2013, 09:35 PM   #4
We just ordered a 24HFS and are planning on putting two Harleys in it. We have a Dyna Low Rider and a Softail Deluxe at this time but hope to eventually get 2 street glides. Have you put both your harleys in the garage yet and if so how did you work the tie downs? We are hoping both bikes fit! would you happen to have a picture of both bikes in the garage? We would love any input you guys could give. we are new to the toy hauler scene.
Jim & Terry
2014 XLR 24HFS
04 Low Rider
08 Deluxe
portert is offline   Reply With Quote
Old 09-14-2013, 11:32 PM   #5
PORTERT, Not sure about loading in 24 HFS , ours is a 27 HFS. I posted some pictures in a thread some time back . Look under XRL and 27HFS haulin harleys.
John And Mary
2013 XLR 27 HFS
Old 09-15-2013, 10:36 PM   #6
aha,someone else with the same shower issues!ok,what i have done is got tablecloth weights with a clip and put them on the bottom of the curtain.its not 100% better,but it definately helps.as far as the tv mount goes,i installed a full motion mount that also tilts.works out alright.weight distributing hitch works well for me,gmc 2500hd towing it,no sway issues ever.
How do you find the beds?my bunk is so uncomfortable,i only slept on it the one time...back was so sore after that.
supreme87 is offline   Reply With Quote
Old 09-16-2013, 07:42 AM   #7
Portert, I use a system similar to this.
ADJUSTABLE MOTORCYCLE TRAILER WHEEL CHOCK BIKE STAND on eBay!
What I do is strap the wheel chock down, drive the bike into it and then strap the bike in. Works like a charm. I put the street glide all the way forward and strap it in, the other bike goes in almost behind it, but angled a little bit using the same wheel chocks.
supreme87, thanks for the tip on the shower I will have to give it a shot and for the bed, I purchased a memory foam thing and put that down under the mattress to give me some extra comfort. it helped a lot, I think I paid $75 for it
Old 09-16-2013, 07:53 AM   #8
Thanks for the info. We ordered the trailer contingent on whether our bikes fit in the trailer. We can not find one on a lot anywhere to go look at and we are not sure how both of our bikes will fit. Was hoping that someone with a XLR 24HFS would have pictures of how they put their bikes in the garage and whether they have enough clearance going in the ramp. My bike is a Dyna Low Rider and my husbands is a Softail deluxe.
Old 09-16-2013, 08:01 AM   #9
Next time I load them up I will take a picture. Both of your bikes will fit in there. I have a street glide and takes up a lot of room, heck if I were to take the bags off, I could probably get 3 bikes in there. Might exceed the weight limit though.
Old 09-16-2013, 08:16 AM   #10
avolnek's Avatar
I show the dry hitch weight of this trailer from the manufacturer is 876 LBS. So yes, I would highly recommend a weight distribution to return much of the weight to the front wheels of the truck. I also would suggest looking at a set of air bags to help keep the truck level with a firm ride. I know the few years before the rams had coil spring rear suspension and this allowed for an air bag to be fitted into that spring... very nice setup, I had them on my previous 2010. Also, with that much weight you may want to look into E rated light truck tires if you don't already have them. You will be okay with the lower rated but the sidewalls of the passenger tires aren't as stiff and can cause the truck to sort of wander in the lane while at highway speeds.
Fresh water can legally be dumped anywhere. I generally open mine up as I am pulling out of the park so it is dribbling down the highway... no right or wrong here really if using some common sense.
Smart thinking, I have a few minor things that I will be sending mine in for after I am done using it for the year.
I do not have your trailer and cant speak for this, but have you looked into an adjustable mount. They make some you can pull away from the wall and position however you would like. Then when you are done you just return it to the stored position.
Are you using the fan above the stove top on the range? Is the vent flap open? The fan there can make a huge difference. We use that fan anytime anything is on the stove top or in the oven.
Have you seen the extendable curtain rods to open up some more space?
Stromberg Carlson Extend-A-Shower RV Curtain Rod/ Drip Rack
I clean mine when it's dirty And when it is convenient for me to do so. I would highly suggest cleaning the roof at least twice a year, if not more depending on what is on the roof. IE tree sap, acorns, snow ect.. I generally get to wash the outside of my camper about every other trip. I just make the time to do while it is in the driveway.
Alex...
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
