Old 05-07-2012, 07:09 PM   #31
abanks's Avatar
That's great. I saw on your other post along with relocating your water pump. Can you take more pics of the pump. I've looked under the bed and cannot figure out where you put it. Thanks for the TV mount idea. I definitely plan to copy.
abanks is offline   Reply With Quote
Old 05-08-2012, 12:53 AM   #32
Namchief's Avatar
Originally Posted by Steve38 View Post
I have more pics if you are interested.
I would love more pics and a little more detail on what you did
Eric
Time spent 2012 in TT 32 days so far and 21 Planned days this Fall with mini trips in between
2009 Chevy Silverado 1500
2012 XLR Hyper Lite 27HFS
1999 Yamaha Grizzly
1996 HD Dyna Wide Glide
Namchief is offline   Reply With Quote
Old 05-08-2012, 05:48 AM   #33
Steve38's Avatar
I think it is a bad idea to travel with TV'S hanging on the walls, so I never do it. I bought these mounts which allow quick removal and multiple mounting areas. Additional wall mounts are available for $12. I have 3 inside the trailer, one set up for the outside of the trailer and two in the house (computer room and garage) When we are not traveling the TV can be used at home.
Marine and RV
Call for addition wall plates.
I used a 1x6 in the front bedroom and a 2x4 in the garage. And a 2x4 for the outside mount, which I store in the front compartment, it's there if I want to use the TV outside. Black felt, glue and a staple gun. Cut the pieces very closely, so they fit tightly. Hand file them so they are wedged into place. I did not bolt them on a 200 mile trip. They did not move. After the trip, I used small "L" brackets to secure them for piece of mind. I do not tow with the TV's hanging, this set up is not designed for it.
I mounted one directly to the wall in the living area, just because a wall stud was readily accessible. More pictures next week when I take the trailer out.
Not to confuse anyone, the first pic is the outside mount. it is not bolted to the trailer. I did not want holes on the outside.
27HFS Things to change from MFG
ID:	13402   Click image for larger version
ID:	13403   Click image for larger version
Steve38 is offline   Reply With Quote
Old 05-08-2012, 06:07 AM   #34
Steve38's Avatar
The small divider wall between the pump and storage area. I made a hole and extended the water pump lines into the storage area. then framed it at the floor so items in storage will not slide into the pump. I may raise the framing if it does not hold things back. For now it works fine. I will take more pics this weekend.
Old 05-09-2012, 09:40 PM   #35
Steve38's Avatar
here is another pic, hope it helps you.
Old 05-09-2012, 09:48 PM   #36
Steve38's Avatar
Eric
Picture of bedroom mount, outdoor mount, garage mount, and small L brackets used to hold them in place. I cut the boards very close so they are wedged into place. I used some felt to cover the indoor boards, glue and staples to hold the felt. Outdoor stores in the front compartment when not used. I painted it with bedliner in a can.
ID:	13504   Click image for larger version
ID:	13505   Click image for larger version
ID:	13506   Click image for larger version
