Old 11-07-2013, 02:09 PM   #1
fast11970's Avatar
XLR 300x12
I have a new 300x12 Toyhauler and was wondering if anyone knows how the D rings are secured in the Garage, I have two Harleys I want to lug around from time to time and would like to avoid dropping the fuel tanks to look for myself.
Thanks in advance-Dave
fast11970 is offline   Reply With Quote
Old 11-07-2013, 11:18 PM   #2
wyo700's Avatar
The d rings should be attached to the frame. All toy haulers should be that way. But I have read of some that have not been attached to the frame. Take the screws out and remove them you should be able to tell easily if they are.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 11-07-2013, 11:34 PM   #3
The d rings are junk, replace them with something more substantial. I put in e track.
Sranch is offline   Reply With Quote
Old 11-09-2013, 11:15 AM   #4
Does the substructure follow the d ring pattern to anchor to anchor down e track; I thought of making a perimeter & middle rail with the d ring pattern in floor?
Mynaway is offline   Reply With Quote
Old 11-09-2013, 03:19 PM   #5
In My XLR 27 HFS the tie downs are screwed through the flooring and into sheet metal plates that run between the side to side frame joints. The screws are approximately 4" long self tapping metal screws, (at least 2 1/2" of the screw sticks out the bottom of the metal plate). To be safe I replaced the screws with bolts, flat washers and nylock nuts.
John And Mary
2013 XLR 27 HFS
2013 CHEVROLET 2500 6.6 DURAMAX
Nights Camped 2012 (7) 2013 (33) 2014 (27) 2015 (34) 2016 (4)
Kaboom is offline   Reply With Quote
Old 12-30-2013, 08:08 PM   #6
My Harley did find during a six week road trip
gary reinard is offline   Reply With Quote
Old 01-04-2014, 11:49 AM   #7
D-rings
The factory D-rings are secured with long self tapping screws through the 1" floor and a metal plate that is welded to the frame of the trailer. They will easily hold your Harley.
andy29847 is offline   Reply With Quote
