Old 04-14-2015, 02:44 PM   #1
XLR 380 Amp Switch
I know this would be better with pictures but I must have accidentally deleted them from my phone and our Rig is located about 80 miles from our home at our river property.
So in the garage of my 380 amp, there are two switch panels. One is a 2 switch panel and the other is a 4 switch panel. The 2 switch panel is for the stereo to turn on/off the speakers, one switch for inside, one for the outside.
The 4 switch panel is what has me stumped.
switch #1 is for the interior garage lights,
switch #2 is for the exterior rear LED lights,
switch #3 is for the exterior side light (opposite side of the garage entry door),
switch #4 I have no idea. Stood outside in the dark and checked everything and could not find any additional lights. I thought maybe it was for the plug in for the washer/dryer connect but the plug works if the switch is on or off.
I need to pull the panel to see if there is even anything hooked up to the switch but seems odd to add a switch if it's not connected to anything. In the living area the main switch panel has 2 spots where there is no switch and it is just covered with a solid cap no switch.
Thanks in advance for any ideas
2015 XLR 380 AMP
clarkchriston is offline   Reply With Quote
Old 04-14-2015, 04:24 PM   #2
XLR Production
Should be for your vent fan in the garage. If it does not turn on, check the switch at the fan itself to insure it is in the on position
bulletbob is offline   Reply With Quote
Old 04-14-2015, 04:42 PM   #3
Thanks Bob I will check that. Didn't even notice there was a vent above the queen bed as we usually have it in the up position.
2015 XLR 380 AMP
xlr
