Old 04-21-2016, 03:22 PM   #1
XLR 380AMP Change Flood Light Bulb?
I have two flood lights above rear door out. Looks to be the same as light above the doors so I tried removing the lens and stopped before I broke something! The flood lights are long and oval shaped.
Anyone want to let me in on the secret? ☺
Sent from my SM-T550 using Forest River Forums mobile app
jb4xx is offline   Reply With Quote
Old 04-21-2016, 07:17 PM   #2
dwhit's Avatar
Location: Chicago, Rochester now GA/SC at Lake Hartwell
I've a 415AMP...assuming we're the same you jus' insert a screwdriver into the upper cut-out. The top pops off and then you pull the lens up and out.
XLR 415AMP, F350 Lariat 6.7 DRW, three bikes, NRA Benefactors.
Heart issues-laid up for a spell
dwhit is offline   Reply With Quote
Old 04-22-2016, 12:53 PM   #3
chpence1's Avatar
I put a very small bead of clear silicone around the lense after changing bulbs.
2005 Dodge Ram Laramie, SRW
5.9L Cummins Turbo Diesel 24 valve
2013 Forest River Thunderbolt XLR 380 AMP
Cow Bell
2010 Star Motorcycle Stratoliner Deluxe
chpence1 is offline   Reply With Quote
light, xlr
