Old 09-15-2015, 08:28 AM   #11
WolfWhistle's Avatar
My first Brisk Air went bad in slightly over a year. Now the one new one has stopped cooling. I'll check it again today, but it seems the Delta is less than 5 degrees. Inquiring minds wonder why Dometic using the finest Chinese labor $.50 and hour can hire, can't make a unit that will last a few years. Buying new will be a gamble; they are too expensive to take a chance on, when the warranty is out. I think I'll try to find an old Coleman off a 20 year old camper that still works perfectly.
Originally Posted by LairdT View Post
We ordered our 30 FQSL with the awning over the slide because we winter in Florida and the Oak leaves get into everything and can stain if they get wet. FYI Breezyhillfarm - the dometic AC bit the dust two weeks ago, and not even a year old! Left it running to cool the dogs and returned to find 95 degree temps inside. Ditto on the bed being hard to make but otherwise like our unit a lot! DW has issues with the cabinets being too high for her, stepstool helps!
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 09-15-2015, 09:49 AM   #12
Part for recall
Originally Posted by WolfWhistle View Post
Hi TG, what is the part needed? I have heard of the recall, but haven't gotten anything from the dealer or FR yet. Maybe my early 2015 isn't affected?
WW
Hey Wolf,
Part needed for recall was a small plastic clamp that holds and supports the romex wire where it goes in to the back of the rv plug. Had to buy pack of 4 at HD.
Tireguy397 is offline   Reply With Quote
Old 09-15-2015, 08:08 PM   #13
Originally Posted by Tireguy397 View Post
Hey Wolf,
Thanks TG. On the back of the plug (inside the access area) a clamp is built in to the plug that seems to hold the orange 2-10 AWG wire. I've thought about pulling out the weather proof plug and checking it out. I have not heard that my unit is being recalled for this issue.
Old 09-16-2015, 07:01 AM   #14
FR came around at the Rally in Goshen and replaced a bunch of these. The connectors can cause some problems.
2014 XLR27HFS
2006 Ford F450 Dually Diesel
breezyhillfarm is offline   Reply With Quote
Old 09-16-2015, 07:10 AM   #15
RooVader's Avatar
As a former owner I loved nearly everything but the bed setup...and I hated that so much I am a former owner. Between my head hitting the blinds, constantly feeling I would fall through the bathroom wall and the cramped feeling I just couldn't even sleep in it. I finally moved to the garage before moving on. I would like to return to the xlr family someday but could only consider one with better space around the bed...and that needs to wait for a bigger tow vehicle.
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
RooVader is offline   Reply With Quote
Old 09-16-2015, 09:49 AM   #16
On my 2016 XLR the orange wire came out of the side of the trailer plug at the back which bent that wire 90 degrees. There is a 1/2 inch hole straight out of the back of the plug which allows the wire to go straight in and takes the bend out of it thus reducing the chance of a bad connection. The part I got from Home Depot fits over the wire and in to that 1/2 inch hole to support the wire and keep it from pulling out. I would send a picture if I could figure out how to attach it.
Old 09-16-2015, 10:37 AM   #17
Are you able to use the paper clip/attach icon?
Name:	FR Attach Picture.jpg
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 09-16-2015, 09:20 PM   #18
Steve, I don't have the window you are showing above when replying, but I do when I create a new post. I tried a new post and upload still fails.
WW
Old 09-17-2015, 06:38 AM   #19
WW,
From a PC (were I do most of my viewing/replying...) you need to use the Post Reply button and not the Quick Reply option.
Name:	FR Post Reply.JPG
Old 09-17-2015, 06:39 AM   #20
WW,
Sorry for the duplicate posting. We will continue this conversation in the other post...:-)
xlr
