Old 10-02-2012, 01:29 PM   #1
XLR - Motorcycle Wheel Chocks in Garage
We have an XLR 2011 305V10 and want to secure wheel chocks for the bikes in the garage floor. We believe that the fresh water tank is located below the garage. Has anyone done this successfully/run into problems doing this? We are still in the process of choosing the chocks....so comments regarding types of motorcycle chocks suitable for transport would also be appreciated! Thanks.
2011 XLR 305V10
2011 F350
2007 Harley Dyna Low Rider
2011 Harley Sportster
campania is offline   Reply With Quote
Old 10-02-2012, 01:49 PM   #2
wmtire's Avatar
What kind of bikes do you have?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 10-02-2012, 01:53 PM   #3
We have a 2011 Harley Sportster and a 2007 Harley Dyna Low Rider.
2011 XLR 305V10
2011 F350
Old 10-02-2012, 02:23 PM   #4
wmtire's Avatar
OK, let me see what my brother uses in his toy hauler. He carries his Goldwing and BMW in it, as well as his custom bikes (he has 8 total). He usually only has the best stuff. I'll get back to you when I find out. I know his are on a removable plate that he can take in and out, when he doesn't need them in the way.
I ride a Kawasaki KLR, so I'm cheap (sorry, frugal I should say) and use this one from Harbor Freight, with no problems.
Motorcycle Stand / Wheel Chock
Old 10-02-2012, 07:10 PM   #5
coderider's Avatar
I am looking at the ones below. They are expensive, but I am not looking to secure them to the deck of my Vengenance. Putting a temp stop board across the patio door to the garage and figuring the weight of the bikes and good straps front, back and to hold the bike into the chock should be sufficient. Not making any quick moves with a 36ft 5-er anyway so if things get to shifting I probably have bigger issues to deal with. Figure, I can take them out once on location and use them to secure the bikes when on location. Ride a Honda VTX-1800 and the wife has a VTX-1300.
These can be secured to the deck as well.
http://store.condor-lift.com/product...ailer%252dStop
coderider is offline   Reply With Quote
Old 10-02-2012, 07:22 PM   #6
Mark S's Avatar
I use the Condor "pit stop" and it works really well. You drive into it and it locks in place. You can then put the securing straps on the bike without even using the kick stand. I used it all summer on my Road Guide Ultra without a problem. I recommend it highly.
Mark
Mark and Joanne
2014 Fun Finder XT 276
2015 Ford F150 Lariat 3.5 Ecoboost 4X4 SCrew Max Tow
2011 Harley Road Glide Ultra
Mark S is offline   Reply With Quote
Old 10-03-2012, 05:30 AM   #7
Thank you everyone for your input. Condors seem to be the way to go. We have heard this before, and there is even a dealer near us in Toronto! We looked at another brand, but it was going to cost $140 extra just to get them to Canada.
My husband would like to secure the chocks into the garage floor, and we were wondering if anyone has done this? We are not certain what is under our XLR garage flooring (plywood?) or how easy it is to remove the freshwater tank directly below the garage....does anybody secure their chocks in floor of their toyhauler? I certainly understand the hesitation to do so.....
2011 XLR 305V10
2011 F350
Old 10-03-2012, 10:39 AM   #8
Linnemj's Avatar
We use condor's and added the lock down plates this spring. There is a 100 gal. Fresh water tank under our garage. Used a local independent RV place to add the mounts for under $175. The bolts supplied by Condor were not long enough so he bought some locally. Our garage is our bedroom so we put a rug over the small plates that remain when you pull the chocks. It works great!
Jim & Nicky
2012 Forest River XLR 29 MBV
2010 Dodge 2500 Cummings
Honda ST1100
BMW R1100R
Linnemj is offline   Reply With Quote
Old 10-03-2012, 05:01 PM   #9
Steve7575's Avatar
Take a look at Wheeldock.com I use it for my Harley Ultra Classic. Drive straight in and out. Works great and is easily removed. I also have used Harbor Freights wheel chock. Don't like it near as much, but for $69, can't beat the price.
Steve7575 is offline   Reply With Quote
Old 10-03-2012, 05:51 PM   #10
pjones1969's Avatar
I use the Biker Bar in my Puma Unleashed, had limited through the floor mounting options, this worked out perfectly, pricey but so is my FLHX, a loose bike would be a nightmare inside your trailer
http://www.turnoverball.com/products/motorcycle
2011 Puma Unleashed 27SBU - SOLD
2013 Sabre 32bhok-6 - SOLD
2012 Ford F250 6.2 - SOLD
2017 Heartland Cyclone 3800
2016 Ford F350 6.7 DRW
B&W Companion
pjones1969 is offline   Reply With Quote
