Old 06-10-2015, 10:22 PM   #11
bulldog4949's Avatar
Yea just gotta find a good pump.
2015 GMC 2500HD Duramax Denali
2015 XLR 300X12HP
2013 Polaris RZR 900 XP
bulldog4949 is offline   Reply With Quote
Old 06-15-2015, 10:55 AM   #12
WolfWhistle's Avatar
I would get and RV water pump that delivers somewhere around 2 gpm and wire it for how you are going to power it. I have a 12v water proof cigarette type plug on the utility side that is protected with a 10amp fuse, so that would be the deciding criteria, for me. I would probably spring for one of the larger bladder tanks that someone has mentioned. Yep, just shop around. With just a quick look I see a pump at HF that is claimed to pump 260 gph, which is probably bunk. But has clips and might last you all you need it to.
12 Volt Marine Utility Water Pump
If I did this alot, I would consider one of the better brands... shurflo or flojet.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 06-15-2015, 01:12 PM   #13
Thanks. I think I am going to get the Little Giant pump with 3/4" ends. It says 5 gpm, and comes with battery cable connections with lots of wire.
I will just string the cables across when needed or wire a plug on that side when I get time.
This should work good enough. We don't do a lot of dry camping so this will suffice.
2015 XLR 300X12HP
Old 06-15-2015, 01:46 PM   #14
Don't get the "driil" type. They don't work (at least not for me...). I got this model from Menards - Sumer 1/12[IMG][/IMG]
I made my own hoses and it worked great on our "test trip" pumping 50gl
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 06-15-2015, 01:49 PM   #15
Sorry the model did not paste - HP Mini VacŪ - Multi-purpose Portable Utility Pump
Old 06-15-2015, 08:27 PM   #16
Thanks Steve. I will look into it.
2015 XLR 300X12HP
Old 06-15-2015, 09:19 PM   #17
dieselbobcat's Avatar
I have used this with good results...$35 from Harbor Freight....
12v Marine Utility Water Pump
It has garden hose thread on both sides... depending on application you might need a washing machine hose (female x female) to hook it to a bladder.
2014 Rockwood Ultralight 8312SS Diamond Edition
2016 F350 Lariat Ultimate Super Duty Crew Cab 4X4
Northern NJ - God Bless America!
dieselbobcat is offline   Reply With Quote
Old 06-15-2015, 09:26 PM   #18
Thanks diesel. How long does it take to pump say 5 gallons?
2015 XLR 300X12HP
Old 06-15-2015, 09:39 PM   #19
It is rated at 200GPH... about a minute and a half...
Old 06-15-2015, 09:41 PM   #20
I use the 45 gal bladder as well for filling...
Question: Does your rig have the winterization port? If so, switch inlet to winterization, use a male x male hose adaptor and draw water right out of the bladder using the onboard pump.
tank, water, water tank, xlr
