Old 06-10-2015, 09:58 AM   #1
bulldog4949's Avatar
XLR Thunderbolt water tank?
We are going to go dry camping in 4 weeks. We have to haul our own water by 5 gallon buckets. Will the no vent cause it to be slow as heck or does it go quickly like just a hole to fill in the older trailers?
I worry since it is a connection to a water hose fitting to fill that it will be slow.
Thanks.
2015 GMC 2500HD Duramax Denali
2015 XLR 300X12HP
2013 Polaris RZR 900 XP
bulldog4949 is offline   Reply With Quote
Old 06-10-2015, 02:07 PM   #2
A pump attached to a battery operated drill
wrsmsgt
2012 HD 2500 DuraMax
2015 XLR ThunderBolt 340x12hp
wrsmsgt is offline   Reply With Quote
Old 06-10-2015, 05:24 PM   #3
Yea seen that. From the fill point the lines go up to the under belly. So I guess a 12v pump will be in order for this.
2015 XLR 300X12HP
Old 06-10-2015, 06:22 PM   #4
Homebrew's Avatar
I purchased one of those 45gallon bags to put on the roof or bed of the truck.
I did not realize there was no vent.
You sure do learn a lot on this forum !
Any suggestions on brand of pump?
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is online now   Reply With Quote
Old 06-10-2015, 06:25 PM   #5
KULAs I looked at mine today and from where the water fill is, the lines go up to the tank from there.
The underbelly is blocking my view when they go up, but I am betting filling with a bag or bucket will not work as gravity will not let it go UP through the lines.
I guess I am in the market for a pump also, that will allow a water hose connection on one end for trailer and another size line to the water supply.
2015 XLR 300X12HP
Old 06-10-2015, 08:36 PM   #6
Taranwanderer's Avatar
Wait, back up a sec: there's no vent for your FW tank? I find that hard to believe. How is that even possible? Is there a chance you're missing it somewhere? Is it a factory defect? More info...
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 06-10-2015, 08:53 PM   #7
I am not saying it doesn't have a vent. This was a question.
I see where I add water to fill the water tank (dry camping) and then the hoses in back of fill hole (under the trailer) run UP into the under belly.
I am asking if I fill the tank through a funnel and 5 gallon bucket if it will go SLOWLY or will it even fill due to the lines going up?
I am thinking I will have to have a pump (pressure) to fill tank and make water travel UPHILL.
Anyone have experience with this? XLR Thunderbolt 300x12hp
2015 XLR 300X12HP
Old 06-10-2015, 08:59 PM   #8
Is the garden hose hooked to the fill fitting an option?
Old 06-10-2015, 09:10 PM   #9
I can fill tank when I pull into the camp with water hose method, but throughout the week I will have to haul water by hand as we use it.
I will haul in 5 gallon buckets from water faucet to trailer and I need a way to fill FW tank back up.
So this is when I will need a pump to fill from 5 gallon bucket into FW tank with some pressure.
2015 XLR 300X12HP
Old 06-10-2015, 10:15 PM   #10
Ok, gotcha. Didn't realize that you wouldn't have a spigot nearby to use. THAT was the piece of the puzzle I was missing.
I have a marine bilge pump stowed under my bed just for this purpose. 12v, can be alligator clipped to your battery, no permanent mounting or wiring needed. Good luck!
tank, water, water tank, xlr
