Old 11-05-2015, 06:05 AM   #31
nomad297's Avatar
Originally Posted by Papa GLS View Post
Blue Ox; simple, clean, quiet & efficient.
You get the same with the Husky Center Line TS.
Bruce
Old 11-05-2015, 06:13 AM   #32
We have the Equalizer it works very well with sway and distribution. but it is a little noisy on the tighter corners.
One thing I've wondered about is the brackets on the trailer frame tend to move around a little. The bolts are not loose but I think the torque on the bars is pretty great so they tend to slide and twist a bit. I was thinking about putting a tack weld on them to hold them in place. Has anyone else had the same issue?
Berjr1 is offline   Reply With Quote
Old 11-05-2015, 06:47 AM   #33
Originally Posted by Play Harder View Post
I still don't understand how some say the Anderson doesn't put enough weight to front axle - when you can measure the front end clearance compressing with each turn or tightening the nuts on the chains for the Anderson - I'm using a 1/2 ton Quadrasteer it's a very heavy 1/2 ton also has airbag suspension - have over 10k on Anderson WDH and it works perfectly my ride is level - now it did take a trip from Ohio to Seattle to get it dialed in - if you don't set it up level from the start then it don't work --- I mean trailer level and truck level once it's all hooked up and done ---
So easy to take on off and store - barely bigger than a normal slide in hitch---
Get out and Play Harder😛
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015😊
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
The Old Quadrasteer is really a 6.0 3/4 Ton truck! It is no longer made,saying it is a 1/2 Ton is quite confusing to people trying to decide on a TV! Youroo!!
Old 11-05-2015, 06:54 AM   #34
OntarioFireFighter's Avatar
Just to further muddy the waters...
I've got a Fastway e2 setup - WDH & friction sway control; and it works very well.
Very similar to the Equalizer... Quick to take on and off, although it is a little on the heavy side.
2014 Grey Wolf 28BH, behind a 2015 F350 Diesel Crew Cab
Nights Camped 2016: 44
Nights Booked 2017: 11
Nights Camped 2017: 6
OntarioFireFighter is offline   Reply With Quote
Old 11-05-2015, 07:10 AM   #35
Yes. I drilled a hole through the bracket and tongue member and put a bolt through. You have to watch for wiring inside and outside the frame.
2014 XLR27HFS
2006 Ford F450 Diesel Dually
2015 Harley Freewheeler Trike (Tara)
2004 Harley Road King Custom (Gemma)
breezyhillfarm is offline   Reply With Quote
Old 11-05-2015, 07:41 AM   #36
If you never want to worry again get a Hensley. I know it's$2000 installed but it's trouble free.
rocrider50 is offline   Reply With Quote
Old 11-05-2015, 07:54 AM   #37
WolfWhistle's Avatar
2008 Can Am Spyder
PH, you are the expert. If you were referring to the comment I made... I have read on the forum that the mounting slips and then the tension changed... dunno really, just read it on the forum.
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 11-05-2015, 12:23 PM   #38
2014 XLR27HFS
Bolt that's a good idea thanks ill watch out for the wiring
Old 11-05-2015, 01:59 PM   #39
roguepra's Avatar
I have a blue ox for my 27hfs...two dressers in the garage and pull it with a 2014 tundra...i have to add water for balast but the hitch works fine...just got back to richmond from fla about 2100 miles and ran 65..70. No problems
2016 XLR 27hfs
2014 Tundra SR5/TRD 5.7 Firestone Airbags
Blue Ox WDH
2015 Roadglide spec
2012 switchback mechanic..(wife's)
roguepra is offline   Reply With Quote
Old 11-05-2015, 02:09 PM   #40
Play Harder's Avatar
WW
No just commenting on other posts that the only argument I've heard against the Anderson is it can't transfer enough weigh to front axle --In my use I can definitely see and feel weight transferred to front axles that's all
Great WDS system
WW going coastal this weekend 😄
Play Harder is offline   Reply With Quote
hitch, sway, weight, xlr
