Old 05-15-2013, 04:14 PM   #21
Originally Posted by Yler4cy View Post
I would like to know this as well, because I can not walk under the 2 beds in my camper. I asked if they could go higher and the salesman said no. Don I will try and get a picture to show you it in the top position.
EDIT: My bed DO NOT go all the way to the ceiling which I wish they did because I have a golf cart with a lift and it would fit if both beds were to go to the ceiling. The way it sits now I would have to pull the pins and remove both bed to get it in there.
Here is a photo of my trailer when i was taking delivery of it from the seller.. you can see the beds are all the way up, but that lower bunk even for someone under 6' tall is low enough to hit with their head.
The bottom bunk, even with the top bunk out, will not go any higher, and the top bunk with the bottom bunk out, will only go 1/2 way down (the position it goes to with the bottom bunk in place..)
Uploaded with ImageShack.us
melk-man is offline   Reply With Quote
Old 05-15-2013, 04:18 PM   #22
Melk - That is exactly how mine looks. I would love for it to go to the roof, because from what I was told is it is 7'9" inside and the beds are only 4" thick. This would give me plenty of room for my beds. I don't care if I have to buy a ladder for them.
2007 Silverado Crew Cab w/ 5.3L
2013 XLR 27HFS
1981 EZGO Customized Golf Cart
Yler4cy is offline   Reply With Quote
Old 05-15-2013, 05:39 PM   #23
the bed may be 4" but the bracket that runs in the track, that the "L" bracket attaches too, i think is taller than that.
My advice, if you are keeping both beds, would be to construct longer "L" brackets. ones that in the "7" position would hold the bed higher.. pretty simple with some steel and a drill ? then enamel em white. I just had no need for both beds. but DO want it in the high position, to come down further. gonna remove those stops and see what happens.
Old 05-15-2013, 05:44 PM   #24
djmac1964's Avatar
This picture shows our bunks in the raised position. If you look closely you can tell that they are just barely visible through the side entrance door. Like I said, I am 5'9" tall and can walk and stand under them with no issues, and no squatting. And my UN lifted cart fits under them with an inch or two to spare.
Don
2013 XLR 27HFS Toy Hauler
2014 Silverado 2500HD Z71 Crew Cab
99 Club Car Golf Cart
djmac1964 is offline   Reply With Quote
Old 05-15-2013, 08:17 PM   #25
10x
Then there has to be some sort of travel stop switches just like your automatic garage door opener at home. I bet there is some sort of travel adjustment switch or something. Something has to control how far it travels up or down. We need to find this information somewhere. Is there anything in the TT paperwork you get when you receive the new trailer?
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
10x is offline   Reply With Quote
Old 05-15-2013, 09:54 PM   #26
it's not an electric or infrared signal thing. it's a mechanical stop that is visible about 4' off the floor in each of the 4 tracks, screwed to the wall. if you watch the bunks come down, the lower bunk will pass by them, but the upper bunk rests right on them and a lever disconnects it from the chain.. stopping it's movement, even as the lower bunk continues on down.
Old 05-16-2013, 06:49 AM   #27
10x
I will check it out when I get home tonite. There has to be a way to adjusted this thing. DJMAC claims he can walk under his with both beds up, I cant on mine.
2014 XLR 27 HFS
Old 05-16-2013, 07:50 AM   #28
djmac1964's Avatar
Here is a cropped version of my pic. You can see how much higher it is than the other pic that was posted. I don't know how to make it happen, but it can happen! I can't even stuff a pillow onto the top bunk when they are raised because it is so close to the ceiling. And yes, I can walk and stand under them without stooping over.
Don
Old 05-16-2013, 09:27 AM   #29
OK, confirmed with Darren our se rep, that removing the stop blocks in each of the 4 tracks WILL allow the upper bunk to keep traveling down. THe upper bunk brackets are not fixed to the chain, the top bunk brackets are just resting on the lower bunk bracket (that is attached to the chains). the stops.. well, "Stop" the upper bunk in the position they wanted when you have 2 bunks.
so, the stops held in with the screws are coming out and i can lower the bed further now that i have no more 2nd bed back there and i can leave it in the upper bed position so it goes all the way to the ceiling.
he also said that if you have the walk through dinette option in the cargo area, that lower bed that folds up would reduce the walk through height due to the folding brackets taking up room below.. but none of us discussing that have that option. we all have just the actual beds. it does appear that Don's lower bed is thinner or something than mine pictured above.
Old 05-16-2013, 02:10 PM   #30
djmac1964's Avatar
Yes, I just have the original mattresses, not much more than a piece of foam. I did have to put plywood under the mattresses so you couldn't feel the frame under you. I also put a layer of camping mats between the mattresses and the plywood thinking it may make it a bit more comfortable. Not to terribly bad now, but still not as comfortable as a regular mattress.
Don
