Old 07-14-2017, 07:56 PM   #1
Additional FW tank
So here it is, my sales order says I have the 60gl additional tank. So, is there only one fill port? How do the tanks fill? I ask because I can only get 100gls into my tank. I'm trying to figure out if I have a fill issue or an issue of paying for something I didn't get.
Model is 2017 T24RQMX
flhtci2006 is offline   Reply With Quote
Old 07-14-2017, 09:02 PM   #2
Trobec's Avatar
Is it a fresh water or grey water tank?
Trobec is offline   Reply With Quote
Old 07-14-2017, 11:07 PM   #3
Fresh
Old 07-14-2017, 11:11 PM   #4
From what I read there is an equalize tube that connects the two tanks.
So you should have 120 gallon.
Those tubes are low and when you get near fill I believe it takes a bit till the other tank matches the one your filling..
Try to wait a few minutes and try to refill some more.
How do you know you added about 100 gallons? Did you measure?
Lawrosa is offline   Reply With Quote
Old 07-14-2017, 11:20 PM   #5
On the website it shows the sport series with a 106 gallon tanks..
There is no option on the sports unit for an additional tank..
Edit.. You dont have the sports series ...lol...
SPORT SERIES STANDARD FEATURES
Heated and enclosed underbelly
Queen innerspring mattress (main bed)
Ducted 13.5K BTU air conditioner
3 burner cook top with oven
2 sofas with pedestal tables
VIEW MORE
6 gal gas/electric DSI water heater
A&E awning with LED light strip
Drive on wheel well (doorside)
102" wide body construction with 8" I-beam
3,000 lb radius ramp door
5,200 lb axles with self adjusting brakes
Aluminum wheels (4)
LED interior lights
Chef's high rise spring faucet
30K BTU ducted furnace
Radius glass shower with surround
Battery disconnect
RVIA seal
Live edge Thermo Foil countertops and tables
6 cu ft double door refer
106 gal fresh water capacity
SPORT SERIES OPTIONS
2 chairs & bay window IPO sofa
Dual 30# LP Bottles (IPO 20#)
A/C 15,000 BTU upgrade
Retractable roof ladder
Water heater bypass
VIEW MORE
3.5K carb portable generator
Single electric bed
Power awning with adjustable legs
20 gal fuel station
Canadian MVSA (all)
CSA Canadian Standard Z-240 (BC)
Arctic Package
Go Power Solar Prep
Entertainment Package - DVD, MP3, CD FM Stereo with 4 speakers, TV antenna with booster, electronics charging stations
Convenience Package - Black tank flush, matching aluminum spare tire, stabilizer jacks (4)
Old 07-14-2017, 11:24 PM   #6
Your model shows 86 gal water.
Plus 60 should be 146 gallons you should get in there.
Old 07-14-2017, 11:48 PM   #7
Well, it just depends on where you get your data from. Here is from the brochure: (oh, and is listed on my invoice)
STANDARD
• 102” Wide Body Construction • Heated, Insulated, & Enclosed Underbelly
• 106 gal Fresh Water
• 13.5 BTU Ducted Air Conditioner
• Recessed Oven w/ Glass Range Cover
• 30# LP Btls w/ Cover (20# on MX)
• 30,000 BTU Furnace, Ducted Heat Throughout
OPTIONS
• 15k BTU Air Conditioner
• 200W Solar Power & LED Light Pkg
• 1500W “Go Power” Inverter
• Additional 60 gal Fresh Water (NA T18CB, T21RQ) (Mines a T24RQ)
• Electric Pass Through Dinette
So, I should have about 166gl. Now, I don't need that much water as it hurts my weights. But, if I paid for it and don't have it, I want some money back.
Yes, I have a flow meter to measure water I put in. That way I can calculate weights.
Old 07-15-2017, 12:20 AM   #8
Yes I see that on the brochure..
So it says on the sales recipt that its what was ordered with the extra tank?
Sometimes its listed on the sales ticket but says N/A next to it.
If indeed you dont have it and should talk to the dealer or forest river.
They are not keen on giving money back. They will offer you something like they did me. They sent me a $400 back up furrion camera. Its a piece of junk so I sold it on e bay for $250..
http://www.forestriverinc.com/brochu...avettflyer.pdf
Old 07-15-2017, 12:32 AM   #9
Well, I would take anything that was same basic cost.
If someone has the extra tank, other than water qty, what's the easiest way to tell? I have looked underneath I don't see one. If someone has a pic with 2 tanks, "pictures for dummies" works for me.
Same issue I looked at with the Arctic Pkg. I was told if it had the sticker, it had the pkg. So I verified it when I upgraded the vents for maxxairs. It was there.
Lawrosa: What camera did you end up with?
Old 07-15-2017, 01:36 AM   #10
They sent me the ferrion one that fits in the prewired bracket on the coachmens.
I didnt like it so im selling it on e bay..
I really dont need a camera to back up and I have too much stuff on my dash alread. GPS, phone, etc...
Is this one... Not sure if im allowed to post this..
Furrion Model FRC12TA-BL RV Back-up Camera New in Box | eBay
tank
