Old 02-26-2012, 11:46 PM   #1
Charging issue
I have a 2010 Shockwave toy hauler 5th wheel. 2 brand new batteries from the dealer I bought the trailer from. They wont charge past 2/3 and then die within 3-4 hours only running the fridge. Anyone have an idea what might be wrong with the charging system? I've already conducted a load test on each batt seperately and they're good.
drommerist is offline   Reply With Quote
Old 02-27-2012, 12:03 AM   #2
TURBS's Avatar
What's the voltage at battery's when shore power is plugged in?
Old 02-27-2012, 12:25 AM   #3
This may some dumb, but did u check to see if by some strange chance, the hooked them in series?? Stranger things have happened!!
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 02-27-2012, 12:41 AM   #4
Something else to check. When shore power is plugged in, can you run a a vacuum off a wall plug? Sometimes, when you plug a camper in to a GFI circuit, the breaker trips, and you just think it is plugged in, when in reality, it isn't getting any power at all. Does the clock on the microwave work? (anothe clue about shore power). Have you checked all the breakers in the panel and RESET them all. Lastly, as post#2 ask, what is the voltage on the batteries when plugged in?
Check every hour and write it down, should show a steady increase, up toward 13.8 volts or so.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 03-01-2012, 08:20 AM   #5
The batteries are not in series. Ill have to check the voltage when hooked up to shore power but while plugged in, all 120v appliances work fine. Thanks for the help, ill get the voltage tonight.
