Old 12-25-2017, 03:03 PM   #1
have you installed shocks or equalizers
I have a 2017 T24RQMX and look to upgrade the equalizers and add shocks. Anyone done this? What did you install and what are your views of it? Pics would be nice.
Barry
flhtci2006 is offline   Reply With Quote
Old 12-30-2017, 08:51 PM   #2
Wow, nobody.
I'm getting ready to add Lippert Correct Track, Equa-Flex equalizers, 1/2" thick shackles, Lippert Never-Fail bushings and Lippert shocks.
Old 12-30-2017, 10:08 PM   #3
NMWildcat's Avatar
Here's what my RV service guy told me. If you plan to full-time, travel >8k miles a year, and plan to keep your rig for 5 years or more, then do it. Otherwise it's not worth the expense for the benefits gained. According to him anyway.
Scott and Liz - Southern NM
Old 12-30-2017, 10:27 PM   #4
Selective Curmudgeon
Halfmast's Avatar
Really like this guy's videos. In this one, he adds suspension and shocks to his Coachmen 360IBL 5er.
Hope this helps.
2016 Ford F350 Diesel Dually
2018 Coachmen Chaparral 360IBL
Halfmast is offline   Reply With Quote
Old 12-30-2017, 11:17 PM   #5
Well, here's the thing. Fully loaded to 400lbs under gross weight (all weights were from a certified scale) with a TW percentage of 12.6% using a properly set up WD hitch, while increasing speed from 35MPH to 55MPH (not having reached the 55MPH) I developed a significant sway which ended up bending all my hanger brackets between 15º and 30º and shifted both axles about 2 inches to the left. The trailer has since been fixed but I know the hangers need some support. The Correct track will do that. Plus, tire clearance unloaded is 2 1/2 inches and that is the minimum you should have...Loaded! Correct track will raise the trailer 2inches. So, added support to the hanger legs, a block between the legs to essentially tie the legs together,2inches more clearance AND, the ability to correct axle alignment. That's a win. The equa-flex will smooth out all oscillations. Shocks will help control the suspension.
As for mileage, I do about 7K to 12K per year. I also go off road since it is a toy hauler and encounter things like off cambers, ruts, dips, holes, etc. As for 5 years, well I'm 62 and when I can no longer safely pull a trailer, I'll quit. Could be one year....could be 20 years.
Old 12-30-2017, 11:21 PM   #6
NMWildcat's Avatar
Wow..... that had to be some sway!!!! Hope all the after market goodies fix your problem. Good luck!!!
equalizer, led
