Old 09-25-2017, 03:19 PM   #1
herbike's Avatar
Mounting heater on wall
I am trying to mount a blue flame heater on the wall of our toy hauler. I cannot find a "stud" any place near where I want to mount it. I tried my "electronic" stud finder thinking it would locate them, no luck. The walls are the foam and fiberglass laminate. Wondering what suggestions you folks may have on mounting it to this type of wall.
Days camped in 15-180 days-16-95 days
17--114 days-18-71-days
19-32
2016 t28FQDX Shockwave, New Provider tires 10/31/18 ,TV-2015 LTZ Duramax with over 151,000 miles, with delete done, 2014 Polaris RZR 800 EPS/ 9800 miles
herbike is offline   Reply With Quote
Old 09-25-2017, 03:28 PM   #2
Just as confused as you
Scrapper's Avatar
Some of the foam/fiberglass laminate walls don't have studs, others do. Some only have any kind of studs around doors and windows and maybe corners where walls join.
Richard & Jill
Camping since 1989, seasonal since 2000
Old 09-25-2017, 03:32 PM   #3
Fulltime family RVer
That's the case for me- there are only studs around the doors and windows with a few others here or there.
I actually took advantage of a dewy morning a couple of weeks ago. You could pretty clearly see where the studs were. I took pictures, measurements, and made some sketches so that I could refer back to them later.
ependydad is online now   Reply With Quote
Old 09-25-2017, 03:46 PM   #4
But unfortunately, I donít have an answer to your real question- how to mount it.
If you can wait for a dewy morning, you can really verify if there are studs or not. You might be able to contact FR/Shockwave to see if wall diagrams exist and if theyíre willing to share them (for my brand, Sabre, people with newer rigs have gotten them but when I asked they said they didnít exist).
As for bolting- I personally would be tempted to glue and screw a larger piece of wood to the wall and then mount the heater to that.
I think OldCoot installed a handrail for his inside (fifth wheel) steps and actually bolted the whole way through the wall to the outside. But, my memory could be faulty on that one.
Old 09-25-2017, 10:09 PM   #5
herbike's Avatar
[QUOTE=ependydad;1632415]But unfortunately, I donít have an answer to your real question- how to mount it.
I thought of doing this with a piece of 1/2 inch plywood. I went ahead and used the nylon anchors that came with it. I checked at a hole we had punched in the wall with a RZR door when unloading one time. I realize the luan covering the styrofoam isn't the strongest stuff but maybe it will work. I'll keep an eye on it. We plan on taking it down in the summer when we don't need it, winter time it will get lots of use.
Thanks for the replies.
Jack
19-32
Old 09-26-2017, 01:28 PM   #6
What's on the outside where you want to install? If clear, drill hole completely through. Mount a piece of polished stainless steel to the inside. Use cap nuts on outside. Sometimes called acorn nuts. Polished panel will reflect heat back into room, prevent wall from getting hot. Then mount heater to this piece of steel. Summertime, remove heater. Place a table in front of panel.
tom3205 is offline   Reply With Quote
Old 10-11-2017, 12:18 AM   #7
herbike's Avatar
A little follow up on the heater install. Used it 7 days in temps down to 18*. Really was a life saver in the evenings when we got too cold to sit out by the fire. Worked as advertised. We did learn we still needed to let the furnace run at night, water to toilet froze one night but thawed next morning, that was the only problem we had with low temps.
Our cat doesn't like it as well as the old radiant heater, she would lay in front of it and sleep. This doesn't "radiate" the heat so she didn't have a hot spot.
Nice to not to have to take a chance with the propane bottle in the camper, a little scary. Now more like home.
19-32
Old 10-11-2017, 11:01 AM   #8
Awesome report! I need to do something to try and conserve propane. When we get into cool days and nights, I go through it like a frat boy and a beer keg.
Old 10-12-2017, 10:42 AM   #9
Head Rambler
That's a neat looking install. Just the pic looks really cozy.
Gotta go campin!
Old 10-12-2017, 11:50 AM   #10
Scrapper's Avatar
You do know that those types of heaters should not be used in an enclosed environment without opening a window for fresh air ventilation?
Many people have died from using them indoors improperly. Anybody remember the kerosene heaters that were popular for extra heat back in the 70's?
Richard & Jill
heater, mount
