Old 07-28-2011, 12:45 AM   #1
Stove Ventilation?
Is there suppose to be a vent hood for the trailer? Or what does everyone do to get rid of the carbon monoxide when cooking?
rsmith is offline   Reply With Quote
Old 07-28-2011, 05:30 AM   #2
If you are concerned with carbon monoxide when cooking, just open a window a little bit. At long as your stove is adjusted correctly (no soot on the bottom of your pans) and you are using it for cooking only, not heating the camper, you should be fine. Make sure you have an operating CO detector. http://www.jolietfire.com/pdf/Carbon-Monoxide.pdf
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 07-28-2011, 06:43 AM   #3
CLASS "A" Senior Member
cfsoistman's Avatar
We have a fan in the ceiling centered from side to side in front of the stove. The Range Hood Fan over the stove is a filtered recirculating fan. It's part of the bottom of the Microwave. I run the ceiling fan on low when cooking to help remove any heat from the stove and crack a window slightly if cool weather outside.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 01-30-2012, 02:27 AM   #4
Just be sure that you unlock the vent flap on the exterior of the wall just beneath the awning. I have to get on a ladder or stool to reach it. They have little levers so while in transit, the flap doesn't slap around.
drommerist is offline   Reply With Quote
