Old 04-13-2015, 12:23 PM   #1
T24FQ MX Onan Generator output issue - Was working great
Hi all,
I am newb to the forum and hope to get some help. I have a new 15 Shockwave T24FQ MX that we purchased in Oct. We previously had a Weekend Warrior for 7 years that we traded in. The Shockwave is a very nice trailer and we are enjoying it. We are for some reason having a generator problem that I discovered on our second outing last weekend. Im not getting any 110 power when the generator is running. It worked great on the first trip. I went through all the wiring and breakers and fuses inside as well as the breaker on the gen (Onan 4k) itself and everything checks. When plugged into shore power the TH has 110 power. I scheduled for a warranty job with the dealer but they cant get it in for at least a month which kinda sucks so I thought I would sign up here and ask if anyone has any ideas.
Thanks in advance!
NVSmithers is offline   Reply With Quote
Old 04-13-2015, 09:56 PM   #2
Rookie19's Avatar
Originally Posted by NVSmithers View Post
Hi all,
Thanks in advance!
Welcome fellow shockwave owner!!!
My guess would be the transfer switch went bad already.... Bummer.
At least it's still under warranty!!!
I'm hoping I have no more issues but if I do I hope I find them by September.
Tow rig - 2006 F350 with some goodies
Trailer - 2014 T27FQDX
Toys - 2005 yfz450 with some goodies, 2005 rhino 660
Rookie19 is offline   Reply With Quote
Old 04-14-2015, 09:54 AM   #3
Thanks Rookie19, I kinda figured that was what it might be after doing more research yesterday. What im not real clear on is where that is located. Is it behind the breaker panel inside the coach or located somewhere else? I might just replace it myself and send the dealer the bill.
Old 04-14-2015, 11:03 AM   #4
Rookie19's Avatar
I honestly don't know. Lol!!!
I think behind the breaker panel but I could be wrong.
Let me know if you find it that way I know.
If it's not that big of a deal I would have the dealer do it so you're not fitting with them on it.... There has been stuff I can do but in mi opinion it's best to have them done on warranty.
Old 04-14-2015, 11:59 AM   #5
You mentioned service at the dealer we contacted an Onan service center and got the warranty work done in a week. Forest River dealers were weeks out. Good luck.
edcronin01 is offline   Reply With Quote
Old 04-14-2015, 12:34 PM   #6
Rookie19's Avatar
That's good to know. My dealer has been amazing though so far!
Old 04-14-2015, 12:35 PM   #7
Yeah I agree. I was able to fix a couple things on the WW and hand it over to the dealer and they covered it. I guess ill have to see how complicated it is before I undertake my own repairs.
Old 04-14-2015, 12:57 PM   #8
Ok..It looks to be this guy which is pretty easily accessible.
http://www.progressivedyn.com/pdfs/110030%20English.pdf
Old 04-14-2015, 01:29 PM   #9
Rookie19's Avatar
So I wonder if the generator has something wrong with it?
Old 04-14-2015, 02:12 PM   #10
My trusty voltmeter should tell me :-)
Old 04-14-2015, 02:15 PM   #11
The transfer switch is usually in the cargo area between the geni and the main fuse panel. you could check to see if a wire came loose inside.
j free is offline   Reply With Quote
Old 04-14-2015, 02:41 PM   #12
Rookie19's Avatar
One other thing I just thought of... Did you check the breaker on the generator itself?
Old 04-14-2015, 02:48 PM   #13
Yep...Checked all fuses from the gen to the panel.
Old 04-14-2015, 04:03 PM   #14
Rookie19's Avatar
Just thought I would confirm. Don't want to look over the little things.
Old 04-14-2015, 04:34 PM   #15
Indeed.....It happens!
Old 04-18-2015, 03:26 PM   #16
In case anyone was wondering I tore power center all apart and found out it was indeed the Power Transfer Relay. The relay itself was sticking and not working. So I messed around with it for a bit, got it loosened up and now it works like a charm.
ID:	74613   Click image for larger version
Old 04-26-2015, 11:44 PM   #17
WR450rider's Avatar
Well done Smithers!!
With the dealer service department out months on their schedule, I'm just learning to fix everything myself as well!
The service schedule just shows you how hastily these things are slapped together!
WR450rider is offline   Reply With Quote
generator
