I'm doing a lot of guessing here: With a GVWR of a bit over 14,000# and a pin weight 2000# plus, you will have about 12,000# or less on 2 axles, or about 3000# on each tire. If true, you might need less than 110 psi. A scale and a load chart will provide the answer.
Any way, your going with better tires and questioning the wheels is a good move. Metal valve stems may also be a good idea.
2017 Riverstone 38FB Legacy
2018 F450
