Old 10-25-2017, 12:10 AM   #1
herbike's Avatar
Wiring for a MaxxAir fan
I'm wondering if there is a hot wire run up by the vents in our T28FQDX Shockwave. Thinking about installing a Maxxair fan in the living quarters of our trailer. If not how do you get to power for a fan.
Days camped in 15-180 days-16-95 days
17--114 days-18-71-days
19-32
2016 t28FQDX Shockwave, New Provider tires 10/31/18 ,TV-2015 LTZ Duramax with over 151,000 miles, with delete done, 2014 Polaris RZR 800 EPS/ 9800 miles
herbike is offline   Reply With Quote
Old 10-25-2017, 02:10 AM   #2
Just as confused as you
Scrapper's Avatar
If you remove the vent trim from the ceiling and look or feel in the gap you should find the loose wires laying there.
Not all vents are pre-wired for a vent fan, in those cases you might connect to a light close by. If the light has a switch on the wall it will have to be on to use the fan. As long as the light fixture has a switch on it, that will work fine, if not then you will have to install a new fixture with a built-in switch or install a switch at the fixture yourself.
Richard & Jill
Camping since 1989, seasonal since 2000
fan, wiring
