Voltage is probably not an issue, as voltage has a varying number that is not always 'exactly' 120volts, but can swing lower or higher within range...
while it seems aggravating to most, generators are typically installed to fit the amperage needs of most coaches, though when breakers start tripping, they soon realize that Shore Power gives them all they need, but their own generator may not seem up to the task.
First, your coach is a 50amp(100amps total) Main electrical panel type, meaning that you can access and use 50amp RV Service from Shore Power, which is two SIDES of 50amp power, with one side having your FRONT A/C unit, and other breakers, and the other side having power to your REAR A/C unit, and other breakers.
When you are using both A/C units at the same time, they are drawing from different hot legs of the power supply, even when the power supply is your generator.
Your generator, though, only has an output of about 25amps PER SIDE, close to 50amps total, NOT the 100amps you get from Shore Power. So, when you are running BOTH A/C units on the generator, the power(amps) that are left is far less than when you are on Shore Power. You'll only have about 10amps left on the side with the larger FRONT A/C unit, and about 15amps on the side with the REAR A/C.
Look in your electrical MAIN PANEL... see which breakers are on the same 'side' of the panel along with your FRONT A/C unit, which is the one you seeing tripping often with. If you have the electric Water Heater on this same side, then turn OFF your elec water heater switch in these situations, as the water heater is calling for a BIG amount of amps when it is working, which can add to the tripping of your breaker while your front A/C is running on your generator.
Ultimately, the other 'things' that are on the same side of power as your FRONT A/C are going to impact 'when' the breaker trips. I'm assuming you are meaning that your Generator breaker is tripping in this situation, which would make sense.
Is it your generator's breaker that is tripping?
The Turners...
