Old 03-05-2016, 04:37 PM   #1
Area 52's Avatar
Air Conditioner Electrical Arcing Heads Up
While running the AC (Dometic) on my 2015 WA2715 the trailer filled with an acrid electrical burning smell. When we opened the junction box
Name:   ImageUploadedByForest River Forums1457217306.626635.jpg
found the insulation burned and two wires that had been arcing. All of the wire nuts had been improperly installed and a ton of electrical tape had been used. All the tape was removed, wires repaired, and new wire nuts installed.
2013 F-150 Ecoboost
2014 WA2715 Stealth
Area 52 is offline   Reply With Quote
Old 03-05-2016, 05:15 PM   #2
Too old to be too smart
SpringerPop's Avatar
It's sad to see what passes for "professional" these days.
Pop
2005 Terry 250RKS, perfect for the two of us and the pups.
It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 03-17-2016, 12:55 AM   #3
PolarisGuy's Avatar
Ever find anything new with this?
RV: 2016 Stealth WA2916 Toy Hauler
TV: 2005 F250 PSD
2012 Polaris Sportsman 850XP
2014 Brute Force 300 (daughters)
2016 Days Camped: 22
Check Us Out On YOUTUBE!!
PolarisGuy is offline   Reply With Quote
Old 03-17-2016, 03:44 AM   #4
Witch Doctor's Avatar
Originally Posted by Area 52 View Post
While running the AC (Dometic) on my 2015 WA2715 the trailer filled with an acrid electrical burning smell. When we opened the junction box Attachment 101132 found the insulation burned and two wires that had been arcing. All of the wire nuts had been improperly installed and a ton of electrical tape had been used. All the tape was removed, wires repaired, and new wire nuts installed.
Lucky you found that, who knows it could have started a fire. Good detective work....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 03-17-2016, 05:19 PM   #5
Area 52's Avatar
PolarisGuy- since making the repairs I described everything is normal. Running the AC every afternoon in the Arizona heat without problem. Next time you clean your filter it might be prudent to open that junction box and have a look for any sign of arcing/burning.
2013 F-150 Ecoboost
2014 WA2715 Stealth
air conditioner, electric, electrical
